10Kw generator powered by JD332 garden tractor
   / 10Kw generator powered by JD332 garden tractor #51
I just bought some por15 for a project and noted it is not recommended for UV exposure. I doubt it would be a problem in your application but just FYI.
Looks like that setup should work well for you.
UV exposure will cause POR-15 to lose its gloss. Otherwise its no issue.
   / 10Kw generator powered by JD332 garden tractor #53
DanMc77 great work! loved reading this thread. You got one impressive Yanmar.
I got a Yanmar too. Or in JE green it's a JD-850. The Yanmar version has a 4=speed PTO. 540, 6XX, 8XX and 1080. The tractor is 27~31Hp PTO, depending on who's source you look at. Whatever. LOL
My eye is on this little PTO driven alt/gen https://www.northerntool.com/shop/tools/product_200308467_200308467 Pricier than a full blown 9000W gas genset, BUT I can run the tractor about 1200rpms with the multi-speed PTO engaged for the easy stuff or to simple charge a battery bank. Thus, the fuel isn't eaten quickly and the noise is nearly a soft purr.
Is it possible to get a PTO gear head set from a brush mower or an auger? It's one way of getting the PTO output up to the 540rpms with a gear head set.
Does your machine have a built in PTO overrun clutch as a safety mean for the PTO? Or is the PTO overrun external?
Maverick,
The JD 332 is a garden tractor with a 16 hp Yanmar engine. The "PTO" is a 7" pulley on the front of the engine with a magnetic clutch. The generator head used with my project is from Harbor Freight and today costs $300. Amazingly, that's the same price I paid for mine about 6 years ago. It took me that long to find the time to do this. Total cost for the whole project was about $350. The bracket was built from junk laying around the house.
I figured I'd post a follow-up on this project now that I have been using it a little more than a year. I have put a good many hours on this thing now and am just thrilled with how well it works and how useful it is. It was critical for running the compressor while we framed up a new garage (remember this place is off-grid). One of my favorite features is the ability to increase the engine RPM a little with the middle-sized pulley. This gives me the ability to super charge tools as needed. In other words, if I need a little more power out of an electric power tool, I can tweak the voltage up a little higher by giving the engine a bit more throttle. I have pushed it up to 150 volts without any issues. Sure, it also increases the frequency, but that's no issue. I have a small portable Hitachi table saw that runs fantastic at 150 volts. I know, I'm taking some risk that I could burn out the motor, but I'm willing to experiment and live with that risk. What I know so far, is that the saw cuts like my larger 2hp table saw does running on grid power wired for 220 volts. The Hitachi running at 150 volts has shown no sign of motor overheating, or any other issue. The middle sized pulley will run anything I need, and if it struggles, then I give it some additional RPMs, but I never go over 150 just because that's the limit I have set, and the meters on the generator don't go much higher than that.
The only downside to the design is that it hangs off the front of the tractor and is quite low to the ground. One time I wasn't paying attention while I moved the tractor, and cracked one of the wood frame members. I fixed it and it's like new again.
This summer the generator failed and I found that the capacitor inside had died. Picked up two new caps (now I have a spare) on ebay and it's back to life now.
   / 10Kw generator powered by JD332 garden tractor #56
Good to hear your setup is working for you :thumbsup:
1964 Mercedes-Benz 190D Car Sedan (A56859)
1964 Mercedes-Benz...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
19010 (A55851)
19010 (A55851)
JCB 2145 (A47477)
JCB 2145 (A47477)
2006 MACK MR CAB & CHASSIS (A57880)
2006 MACK MR CAB &...
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
