10A Relay Fuse
/ 10A Relay Fuse #1
SpaceBuckaroo
Keokuk, Iowa
LS
Today the 10A Relay Fuse blew on my R4041H. I changed it and everything seemed to be okay, and then it blew again. Does anyone have a schematic of this circuit?
/ 10A Relay Fuse
Okay, I finally figured out what was causing my 10A fuse problem.
A couple months ago, I replaced my seat with a fancy, but cheap seat off Amazon.com. The seat is cheap, but I like it because it has a lot of travel in the bounce when I hit hard bumps.
Anyhow, the seat was cheap, along with the built in safety switch. The safety switch was crap. It would cut power off several times even when I was sitting on the seat. I eventually disconnected the safety switch and put a little jumper across the connector. That worked great for a couple weeks, but the jumper would sometimes slip and I'd loose power again.
Yesterday, I was working hard and it cut out again, I got pissed and cut the connector off, and twisted the wires together, and just let them lay next to the seat.
What I didn't know, was that today, while bouncing around, the wire shorted to ground and caused the 10A fuse to blow.
After posting asking for a schematic, it occurred to me to inspect the wires that I twisted together, and sure enough I could see where the wires were burnt along with some insulation. A little shrink wrap and that problem is now fixed.
/ 10A Relay Fuse #4
Hey, you can't say that word. I got a 30-day suspension for a similar phrase.
I was told there's too many children reading the Tractor Forum. 😏
/ 10A Relay Fuse #5
^^^ Weird ... I guess the kids are supposed to feel safe all the time? A switch would indicate that they might face something unsafe in life?
/ 10A Relay Fuse #6
It must ok for some and not others.
1960 IH Farmall Cub Tractor (A66285)
1960 IH Farmall...
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
2010 Chevrolet Express 3500 Dive Team Cargo Van (A64556)
2010 Chevrolet...
