10A Relay Fuse
/ 10A Relay Fuse #1
SpaceBuckaroo
Member
Keokuk, Iowa
LS
Today the 10A Relay Fuse blew on my R4041H. I changed it and everything seemed to be okay, and then it blew again. Does anyone have a schematic of this circuit?
/ 10A Relay Fuse
Okay, I finally figured out what was causing my 10A fuse problem.
A couple months ago, I replaced my seat with a fancy, but cheap seat off Amazon.com. The seat is cheap, but I like it because it has a lot of travel in the bounce when I hit hard bumps.
Anyhow, the seat was cheap, along with the built in safety switch. The safety switch was crap. It would cut power off several times even when I was sitting on the seat. I eventually disconnected the safety switch and put a little jumper across the connector. That worked great for a couple weeks, but the jumper would sometimes slip and I'd loose power again.
Yesterday, I was working hard and it cut out again, I got pissed and cut the connector off, and twisted the wires together, and just let them lay next to the seat.
What I didn't know, was that today, while bouncing around, the wire shorted to ground and caused the 10A fuse to blow.
After posting asking for a schematic, it occurred to me to inspect the wires that I twisted together, and sure enough I could see where the wires were burnt along with some insulation. A little shrink wrap and that problem is now fixed.
/ 10A Relay Fuse #4
Hey, you can't say that word. I got a 30-day suspension for a similar phrase.
I was told there's too many children reading the Tractor Forum. 😏
/ 10A Relay Fuse #5
^^^ Weird ... I guess the kids are supposed to feel safe all the time? A switch would indicate that they might face something unsafe in life?
/ 10A Relay Fuse #6
It must ok for some and not others.
Pallet Fork Extensions (A64047)
Pallet Fork...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2019 Nissan Sentra Passenger Car, VIN # 3N1AB7AP9KY318147 (A61574)
2019 Nissan Sentra...
2007 TROXELL 150BBL ALUMINUM VACUUM TANK TRAILER (A63569)
2007 TROXELL...
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
