1070 starting trouble
/ 1070 starting trouble #1
BerlinBo
1070 has had starter, relays, battery replaced. new relays click, lights work, current is moving through the wires to and back from the starter. But no crank, small "clank" at starter.
/ 1070 starting trouble #2
Try jiggling the gear shift lever, might be the neutral safety switch. Other than that it sounds like you might have a bad starter.
Corrosion inside the positive cable, after the crimped end, was the final piece. Strating system is rejuvenated, and the tractor is running well.
2011 Polaris RZR 900  (A62679)
2011 Polaris RZR...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2021 John Deere 4044M (A64126)
2021 John Deere...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
