1070 starting trouble
/ 1070 starting trouble #1
BerlinBo
1070 has had starter, relays, battery replaced. new relays click, lights work, current is moving through the wires to and back from the starter. But no crank, small "clank" at starter.
/ 1070 starting trouble #2
Try jiggling the gear shift lever, might be the neutral safety switch. Other than that it sounds like you might have a bad starter.
Corrosion inside the positive cable, after the crimped end, was the final piece. Strating system is rejuvenated, and the tractor is running well.
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
Unverferth Perfecta 12 (A64126)
Unverferth...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
