1046 engine problem
/ 1046 engine problem #1
anthonyk
houston texas
Century 3647
I've got a new 1046 with only 23 hours on it.
Yesterday when I started it up, it starting this sort of "rolling" effect with the engine rpms. Even at full throttle. Sounds like I'm revving and dropping the rpms. If I pull the choke and then release it, it'll smooth out, temporarily, then it starts again.
Any suggestions? I can't believe I've got a clogged fuel filter already, I'm buying premium gas for it.
I'll be checking the filter today, but just wondered if anyone else had run into that.
thanks,
anthony
/ 1046 engine problem #2
Do the RPM's roller-coaster while under load as well? See if you've got bubbles/air in the fuel filter when this is happening. Might help pin-point a fuel pump problem. Why bother running high octane gasoline? It's your $, but hi octane will not help you in any way for this application.
G/luck
Joel
/ 1046 engine problem #3
It sounds like governor problems to me. Is there a stick or something stuck in the governor linkage. Is the linkage free?
Good luck,
Doc
/ 1046 engine problem #4
First I would check the air filter precleaner and the filter. Then check to make sure you are getting fuel from the fuel pump. You can check this by disconnecting the rubber hose that goes to the carburator. Catch the fuel as you crank the engine. If that appears to be ok, I would finally check the governor area for something obvious. It sure sounds as if the engine is not getting enough fuel if applying the choke temporarily makes the rpm's smooth out. The Kohler web site has several pdf files that can be downloaded in regards to the CV23 engine that is on your machine. Good Luck and hope you find the problem. /forums/images/graemlins/smirk.gif
/ 1046 engine problem #5
Sounds like a sticky float valve to me. If it has a needle with a rubber tip chances are that's the culprit. Don't bother trying to clean it, just get a new one.
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
213137 (A64276)
213137 (A64276)
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
1992 Rammax 7430 Trench Packer and Extra Set of Drums (A62613)
1992 Rammax 7430...
2014 Toyota Tacoma Ranch Camper Shell (A64126)
2014 Toyota Tacoma...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
