100 hp Box blade
/ 100 hp Box blade #1
AllDodge
Platinum Member
S, Central, KY
Terramite T5C, Kubota M9540HDC24, F3990, RTV1100, Cat 416C, D3B, 955L
Want a box blade that can handle 100 hp or more, and at least 7 feet wide. Been looking around and there are a lot of BB out there but most are not for large tractors. Have a bunch of areas I need to smooth out
Look at the LP HR3584 and got a price from Glassgow Kubota and it was $4500. Could not believe they want that much for it. My MTL grapple weight is just as much and has 2 large cylinders and is less then half the cost
Who makes a good heavy box that can take more then 100 hp?
/ 100 hp Box blade #3
That Landpride is a good unit that you won’t tear up. I bought a 9’ Bush Hog blade just as heavy brand new in about 1988 and it cost over $2000 and it had been sitting long enough to be faded pretty badly.
/ 100 hp Box blade
Have looked at EA and need 7.5 feet
Do like LP, but not at 4K for a box blade.
Haven't had time to call Bush Hog yet
This sight was down for a while today
/ 100 hp Box blade #5
I have that model. It's an old version. I paid $1000 used. The box is indestructible. Only weakness would be the scarifier beam latch. Make sure it's fully latched before applying HP. Otherwise I have no complaints and never worry about "bending" it during use on my M9540.
/ 100 hp Box blade #6
Yep quite a while . . . check out Rhino.
/ 100 hp Box blade #7
Our EA 60-125 box blades are built extremely well and they provide you with an excellent value.
Travis
Xtreme 60-125 Standard Shank Box Blade
Xtreme 60-125 Large Shank Box Blade
Don't go tryin it for sport, but this one uprooted quite the rock..
/ 100 hp Box blade #8
I bought a new Land Pride HR3584 rated to 120 pounds weighing 1119 pounds and it work great on our M8540HDC; Woods has some nice big ones or used to, but no dealer in my area.
/ 100 hp Box blade
Thanks, it does look like a beefy box, and I can afford it, just don't want to spend that much for it.
Found a old 7 ft Massey Ferguson with mechanical (single lever) lowered teeth in good shape. I could add a hydraulic cylinder to go that route. It doesn't have the edge that can set to swing is about the only missing item
/ 100 hp Box blade #10
That should work well for you.
New/Unused Spirit Electric Tricycle (A65583)
New/Unused Spirit...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
New/Unused CFG Industrial MH12RX Mini Excavator (A65579)
New/Unused CFG...
Skid Steer Finish Mower (A65640)
Skid Steer Finish...
2015 Freightliner (A64119)
2015 Freightliner...
3145 (A63117)
3145 (A63117)
