100 hour service
/ 100 hour service #1
RedRocker
Bowie TX
Kioti CK30 HST, dual remotes, FEL.
Am I reading correctly that you don't change the hyd fluid in a CK30
at the 100 hour service?
/ 100 hour service #2
I currently have 180 hrs. Changed all fluids and filters at 50 and the engine oil and filter at 100 and 150. I plan on doing all fluids and filters again at 200.
/ 100 hour service
The dealer did my 50 hour, not sure if he did the hyd fluid, but did the filters for sure. I've never had any external hyd stuff hooked up, so it's never been contaminated. Thanks for the info Hodak.
/ 100 hour service #4
I did'nt change the fluid in mine, just the filters and engine oil.
/ 100 hour service #5
I read the manual as hydro oil is to be changed at 50. Then again at 400 and every 400 thereafter. That's what I did so now at 385 I am looking ahead to a hydro oil change. Yes, this is the big 7 gallon sump with the three plugs.
/ 100 hour service
Thanks again, guess I'll be busy this weekend.
/ 100 hour service #7
Gentlemen,
I received my filters from Amy yesterday and want to change the oil (100 hr) this weekend.
I'm at work and don't have the book in front of me. I also can't remember how much engine oil I used at the 50 hr and I want to stop on the way home and get the oil.
If I remember correctly (fat chance) I believe it calls for something like 1.5 gallons.
Am I even close?
Thanks,
Tom
/ 100 hour service #10
I get exactly two engine oil changes out of 3 gallons and the oil level has read just over the full mark on the dipstick every time.
I found Kioti was way off mark when they listed the front axle lube capacity but the 1.5 gallons on the engine oil has been just right. Oh, and I always change the oil filter.
New/Unused Landhonor 72in Rock Bucket with Teeth (A65583)
New/Unused...
Mack Fuel Truck (A63688)
Mack Fuel Truck...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63688)
2004 Cadillac...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
2021 Caterpillar 302.7 (A64126)
2021 Caterpillar...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
