10' rotary cutter blade problem...
/ 10' rotary cutter blade problem... #22
Make sure you get the correct gear box when you pull the trigger. Call as prices vary at salvage places. Get on the web.
Dumb question- do I use oil or grease in the new gear box?
/ 10' rotary cutter blade problem... #24
That can be debated.
MFG's usually spec oil. And gear oil does indeed do a better job lubricating. The problem is when you loose the seal, and all the fluid, the gearbox is usually trashed before you know it.
Many "old timers" never used oil. Just a light weight #0 or #00 grade grease. IT dont leak out like gear oil when you loose a seal. So no damage. Many really old cutters are still going strong and probably never had anything but grease in there.
IMO.....both work. Its up to you to decide but I dont think either decision is wrong.
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
24in. Bucket w/ Teeth Excavator Attachment (A64194)
24in. Bucket w/...
2022 Case TV450B (A64126)
2022 Case TV450B...
2006 GODWIN GHP45KW-RC-45KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
Toro Groundmaster 580-D Lawn Mower (A66285)
Toro Groundmaster...
