10' rotary cutter blade problem...
/ 10' rotary cutter blade problem... #22
Make sure you get the correct gear box when you pull the trigger. Call as prices vary at salvage places. Get on the web.
Dumb question- do I use oil or grease in the new gear box?
/ 10' rotary cutter blade problem... #24
That can be debated.
MFG's usually spec oil. And gear oil does indeed do a better job lubricating. The problem is when you loose the seal, and all the fluid, the gearbox is usually trashed before you know it.
Many "old timers" never used oil. Just a light weight #0 or #00 grade grease. IT dont leak out like gear oil when you loose a seal. So no damage. Many really old cutters are still going strong and probably never had anything but grease in there.
IMO.....both work. Its up to you to decide but I dont think either decision is wrong.
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
2023 New Holland Powerstar 90 Tractor (A65579)
2023 New Holland...
Cow Skull Decoration (A64127)
Cow Skull...
JCB TELESKID (A65053)
New/Unused ATS...
