10’ Western Heavyweight conversion to Tractor front 3 point hitch ?
   / 10’ Western Heavyweight conversion to Tractor front 3 point hitch ?
Are you keeping the lights and pump all together as the pictures show? I remember that you mentioned the ability to throw it on a truck would be nice.
I’d like to, but these projects get “scope creep” that never seems to end.
For now, I have decided to remove pump, lights, and upper brackets.
No reason I couldn’t get Western Heavyweight truck mounting brackets and put them on my Ram, but I really don’t want to plow with it anyway.
For now, it’s going to be a just a tractor plow. If I run into a cheap used mounting kit, I could possible make it usable on the Ram.
   / 10’ Western Heavyweight conversion to Tractor front 3 point hitch ? #32
Keep the Ram out of the SALT!
I think that once you plow with the tractor and it's near perfect visibility and maneuverability it'll be hard to go back.
Yeah, I agree. I was born of depression era parents, so I try to squeeze every bit of versatility out of everything I can.
I think I will sell the pump, lights & upper bracket mount.
I think the upper 3 point link will have to be rigid piece of steel, not a chain.
The front point has the float option, which would allow it to float over bumps. Also, the moldboard trips.
If I used a chain, I would not be able to “scrape”.
This is what I am trying to achieve-on a more limited budget. Note this plow is trip-edge, mine it moldboard trip.
   / 10’ Western Heavyweight conversion to Tractor front 3 point hitch ? #36
It should work fine rigid. Just adjust your top link so that the A frame is level on the ground.
However you attach what replaces the chain needs to be pretty rugged. Hitting a bump or something that would cause the blade to trip is going to put a good (compression) load on this piece because it's effectively wanting to lift the whole 3 point assembly with it.
I am going to use 3/4” steel bar for the rigid upper link. It will be bolted top & bottom.
Project is beginning to come together. Now I just need an HOA road to plow. That will probably come next year. Trying to teach my son to plow with tractor, too.
So I finished up a bit more work on the plow. Bolted on the new cutting edge and drilled out a piece of 3/4” to make the top link “rigid”.
Not sure if this will work. I think I might end-up bending the top link? Maybe not. The moldboard trips, but :unsure:
Sorry the pictures are crappy. It was dusk and the lights weren’t on.
   / 10’ Western Heavyweight conversion to Tractor front 3 point hitch ? #39
I think you're probably safe but even a 1/4 or 3/8 x 2" flat welded on the 3/4 to make a "T" would make it very unlikely to bend and as you say there's the trip action...
Once there's a little kink in the straight line of the top link it might get worse, at least bend more with a lesser impact.
The more I think about it the more I'd suggest reinforcing it because even with the trip there's a momentary impact that's trying to lift the 3 point hitch and all the linkage. All going through that t/l.👍
I’ve seen quite a few home made front hook-ups like mine with just straight flat stock that weren’t bent, but maybe I should have done a “T”. I was thinking most of the force is down low and will transfer energy through the lower links.
2016 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2016 Peterbilt 389...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
2013 BMW 328i Sedan (A56859)
2013 BMW 328i...
