1/4-18 thread machine screw?
/ 1/4-18 thread machine screw? #21
Looked on British Tools and Fasteners web site, thought it might be Whitworth or some other odd ball; they list their NPT 1/4"-18 tpi tap as being just that (1/4" diameter x 18 tpi). Catalog #5915 ???
/ 1/4-18 thread machine screw? #22
NPT 1/4" usually isnt even close to the same as bolt sizes. Did they happen to mention what drill size to use with that tap??
/ 1/4-18 thread machine screw? #23
i agree.. you are getting near 3/8 with that npt pipe stuff..
/ 1/4-18 thread machine screw? #24
Still say its a #14
/ 1/4-18 thread machine screw? #26
All the #14's I have been seeing are 14TPI, not 18...
Correct diameter though...
True, but a Type B has finer threads than standard.. ;)
In any case, its a self forming thread and would work..
/ 1/4-18 thread machine screw? #27
Even all of the type B's I seen were 14 TPI
/ 1/4-18 thread machine screw? #28
Would these windows be made in England? In the 50's there were a lot of british whitworth sizes out there. I had a couple of BSA's and a 1956 English Ford car. Matching was a pain......
/ 1/4-18 thread machine screw? #29
It's almost as if someone set up a screw machine wrong. Had 1/4" stock and 18 thread per inch cutters just adjusted them until they made threads?????
I've been watching this to see if the mystery is solved.
/ 1/4-18 thread machine screw? #30
Strange alright. Could always buy lo grade 1/4-20 and give em a stretch
/ 1/4-18 thread machine screw? #31
Kinda what I was thinking at first as well. Someone made some screws and did it wrong.
But...How did they tap the holes???
Mystery indeed
/ 1/4-18 thread machine screw? #33
not solved yet. i've sugested going 5/16-18 with a tap. it's the least invasive i think.
/ 1/4-18 thread machine screw? #34
That would "yield" you a 1/4-18!
Well, :confused3: it would neck down a little - but close enuf. ... Actually, tapping to 1/4-20 should be plenty strong since the nut has greater thread root and thus its threads have inherent strength advantage over those on the bolt.
And heel be able to use either bolt. :D.
/ 1/4-18 thread machine screw? #35
base material is aluminum.. have to take that into consideration as well.
/ 1/4-18 thread machine screw? #36
A weaker nut metal would make some difference, but i didnt see it stated.
larry
/ 1/4-18 thread machine screw? #37
At this point, I'd think one of THESE
Amazon.com: ramset
Would be lookin' pretty good.. :thumbsup: Steve
And yes, I'm kidding...
John Deere 8320R (A64126)
John Deere 8320R...
2025 HOMESTEADER 612IT 12FT ENCLOSED TRAILER (A59914)
2025 HOMESTEADER...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
3pt 14' 15 Shank Chisel Plow (A64127)
3pt 14' 15 Shank...
