1/2" to 3/8" adapter problem
/ 1/2" to 3/8" adapter problem #1
Jsandy
Georgetown, De
John Deere 4710
I'm running a JD 4066R (open station) with a factory installed 3rd function that I normally use to run a grapple. The hydraulic connections on the tractor and the grapple are both Pioneer 4000 -3P series. (3/8" body with 3/8-18 NPTF threads). I bought a hydraulically angled snow plow for my FEL. I didn't check before hand but it arrived with 1/2" flat faced connections. I thought , "No problem" and bought another Pioneer 4000-3P connection set. I looked around and found a couple 1/2" female NPT to 3/8" male NPT reducers. I did some research and the NPTF threads are supposed to be compatible with NPT threads (just need to use teflon tape). When I went to dry fit them together the 3/8" male end of the reducer will only screw in about 3 threads (a little less than half way). It clearly is not bottoming out. I double checked (the reducers came from Graingers) the specs and the reducer is 3/8-18 NPT while the Pioneer connector orifice is listed as 3/8-18 NPTF. Since the NPTF (F stands for "fluid") is supposed to be compatible with NPT I can't figure out what is wrong. BTW I found a similar (different brand) reducer later at TSC and the same thing happened. It screws in 3 threads with 4 threads still showing. Any ideas? Thanks.
/ 1/2" to 3/8" adapter problem #2
They are tapered threads. Three turns by hand sounds about right. Pick up a couple wrenches and turn them until they are tight.
Thanks for the responses. A little more research led me to the same conclusion. I have some pipe dope with teflon and will wrench them together this morning.
/ 1/2" to 3/8" adapter problem #5
Loctite 545 for hydraulic connections worked better for me than the teflon pipe dope.
/ 1/2" to 3/8" adapter problem #6
For fuel and oil connections with pipe thread I use a drop of aviation permatex. Mainly because I have it on hand but also because it is resistant to both liquids.
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
Pallet of Hay Tedder Tines (A64119)
Pallet of Hay...
2012 Dodge Grand Caravan Van (A61574)
2012 Dodge Grand...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
CHEETAG CH-5 BEAD SEATER (A64276)
CHEETAG CH-5 BEAD...
