1,000 Hour Mark
/ 1,000 Hour Mark #21
You only replaced the air filter bracket once? My just broke at 190hrs last week. Except I used the heavy zip tie fix and removed the broken bracket since I figured a new one of the same design would break again in a couple years.
/ 1,000 Hour Mark #22
/ 1,000 Hour Mark #23
My B8200 is at 1000 hours. I change about 40-60 hours, sometimes 70.
I don't put any more than that in a year. I change my equipment oil and air filter annually. Things get dusty around my area, so I do not feel bad about replacing the air filter. Over winter, moisture buildup ect does not help the oil. So, I change them every spring before I start mowing.
Sounds like this BX got hours faster than my B8200; mine was built around '85 or '86. 20 years, 1000 hours.
/ 1,000 Hour Mark #24
SKID STEER FORKS (A62613)
SKID STEER FORKS...
REMINGTON ELECTRIC POLE SAW (A62613)
REMINGTON ELECTRIC...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
Abaco Machines DVL500 Vacuum Lifter (A61573)
Abaco Machines...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
