08 CT230/CK30 leak at block and tranny
   / 08 CT230/CK30 leak at block and tranny #1
Toddinmn
Dayton
None
ATTACH=CONFIG]654054[/ATTACH] ct230.jpeg
Long time lurker first time poster. It is leaking right behind the hose clamp and below the dental pick where I think the engine and tranny meet. There is a big gap on the block side that appears to be a casting flaw perhaps. Has anyone else seen or had this problem or have any solutions? The leak turns to a spray when running.
   / 08 CT230/CK30 leak at block and tranny #2
Hello! You've verified the spray is coming from the gap? BTW, not entirely sure which gap you're talking about. Can you circle it or point it out a bit better on the picture? Hydraulic fluid or engine oil?
I think any casting flaw would have presented an issue long before now. If fluid just started spraying, it's probably because either a seal gave out or something broke.
   / 08 CT230/CK30 leak at block and tranny #3
Definitely hyd fluid probably coming from one of those lines. Where is this located on the tractor? Need a better picture if we are going to help.
The leak is hydraulic fluid. It is coming from where the arrow is in the picture where the gap is between the block and the tranny.
   / 08 CT230/CK30 leak at block and tranny #5
Can you maybe pull back and get more of a macro shot? Maybe a video posted on YouTube or something? Hard to tell what it could go to. Regardless, it's likely broken or has come free somehow.
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
2011 KENWORTH T370 (INOPERABLE) (A58214)
2011 KENWORTH T370...
TANK MANIFOLD (A58214)
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
