05 4310 won't go in to gear
   / 05 4310 won't go in to gear #1
Don Anderson
John deer 4310
Hello, I'm experiencing Interment problem with power reverse not engaging .part #LAV10881 took it apart cleaned connections everything looks good reinstalled no go . Looked for bad wires, connections all looks good . code reads one long ,one short followed by six more short ones. Tried it again and it's now working I need to resolve this issue .I've researched for the codes on line no help there just rabbit trails, manual is no help .Anyone got any clues ? It must be the part or an electronic issue before I drop $225 on the part I was wondering if anyone has experienced this Issue Thank you
in
hello,
   / 05 4310 won't go in to gear #2
I don’t know if you ever got this figured out. I had same problem, found a push button that is pressed when the clutch is pressed in. The part was bad. Super easy to replace. Cost about $20.
Hey Thanks It's been a year since I visited this site It still does it once in a while...I'll check it out!
Miscellaneous Projectors (A56860)
Miscellaneous...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
New/Unused Electric Golf Cart (A57453)
New/Unused...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
