05 4310 won't go in to gear
   / 05 4310 won't go in to gear #1
Don Anderson
John deer 4310
Hello, I'm experiencing Interment problem with power reverse not engaging .part #LAV10881 took it apart cleaned connections everything looks good reinstalled no go . Looked for bad wires, connections all looks good . code reads one long ,one short followed by six more short ones. Tried it again and it's now working I need to resolve this issue .I've researched for the codes on line no help there just rabbit trails, manual is no help .Anyone got any clues ? It must be the part or an electronic issue before I drop $225 on the part I was wondering if anyone has experienced this Issue Thank you
in
hello,
   / 05 4310 won't go in to gear #2
I don’t know if you ever got this figured out. I had same problem, found a push button that is pressed when the clutch is pressed in. The part was bad. Super easy to replace. Cost about $20.
Hey Thanks It's been a year since I visited this site It still does it once in a while...I'll check it out!
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
SKID STEER MOUNT & TOOLBOX (A52708)
SKID STEER MOUNT &...
44505 (A56858)
44505 (A56858)
2011 JACK COUNTY 130BBL VAC TRAILER (A55745)
2011 JACK COUNTY...
2009 Dodge Ram 3500 Flatbed Truck with Liftgate (A55973)
2009 Dodge Ram...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
