Firepower 350 Oxy/Acc torch setup
/ Firepower 350 Oxy/Acc torch setup #1
BloomingtonMike
John Deere 3320
I bought a Firepower 350 setup today new in box for $149.99 at Farm and Fleet here in IL. There is one more local at our shop but looks to have been opened for inspection. Price on it looks real real good. If you have a F&F near by and are in the market for a torch setup you may want to check this setup out.
Detailed Description
The 350 series outfits are made especially for the toughest needs - construction, heavy fabrication, large farm implement repair and all other torch jobs. The larger 350 Regulators, Hose, Handles, Attachment, Tips and Nozzles get higher gas volumes to the work. Thus, the 350 Series gives you extended capability for welding, brazing, cutting and multiflame heating. 350 Series outfit includes a #2 welding nozzle and #0 cutting tip that welds up to 1/8" and cuts to 1/2". Optional tips allow you to weld to 2" and cut to 8". Built-in flashback arrestors. Torch handle includes built-in check valves for added protection (safety) against "reverse flow of gases." Tip Cleaner. 2 year limited warranty. Solid brass and stainless steel construction provide years of trouble-free performance.
/ Firepower 350 Oxy/Acc torch setup #2
I have had a Firepower set for 3 yrs or so that looks to be like yours, I forget the number and they are ok, but I would not consider them really professional grade. No complaints at all mind you, just not as heavy duty as my old US built torches.
I use mine with propane for cutting up scrap.
/ Firepower 350 Oxy/Acc torch setup #3
I have one for personel use at home. Worked good for years and everything like tips are interchangable with Victor. No problems at all, and from what I understood when I originally purchased it, it was Victors cheaper name to compete with the other cheap competition. As BloomingtonMike says, it's $150. Price a name brand like victor or others and it will make you think twice and look again.
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
2023 HANGCHA CPYD30-XW71F STRAIGHT MAST FORKLIFT (A62129)
2023 HANGCHA...
5ft 3 Point Hitch Rotary Cutter (A61166)
5ft 3 Point Hitch...
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
