Culvert Advice -- Plastic vs. Galvanized ?
/ Culvert Advice -- Plastic vs. Galvanized ? #1
CurlyDave
Elite Member
Grants Pass, OR
JD TLB 110
I need to put in a 20' culvert to extend a road to an RV pad I am building. I need to be able to drive both a 14,000 # motorhome and my 8000 # tractor over the culvert, not at the same time.
I have seen both metal and plastic used, the costs are close in my area.
Which is the preferred type & why?
Second question:
How do I tell what size to use? The county says 12" minimum everywhere, but for the difference in cost I would rather do it right (maybe some overkill) the first time than replace it next year if it is too small.
From the topo map, it looks like the water from 10-20 acres of 15%+ slope drains through this spot. The culvert will have about a 10% slope.
I am sort of leaning to 24" diameter, which only costs twice as much as 12".
The culvert is going into a natural gully and not a ditch. I looks to me like there will be over 3' of fill over the culvert at one end, and over 5' at the other.
Third Question:
Do I need to fill around the culvert with gravel or can I just use the dirt I excavated for the RV pad?
Forth Question:
Should I have some kind of grate to prevent debris from entering the culvert?
/ Culvert Advice -- Plastic vs. Galvanized ? #2
CurlyDave,
I like plastic since it won't rust.
You need at least 12" of material over the culvert to get the maximum strength. Mine is covered maybe 6"-8" but it handled 55-60,000 pound dump trucks just fine.
I used ABC to cover the culvert since that is what I was using to build the driveway. Most people would use whatever soil they had available.
I think mine is 18" in diameter. I got mine for free so I used it. I don't get much water in mine since the culvert is only about 50 feet from the top of a hill. I would want 18" or larger culvert since I think it would be harder to stop up in the first place and if it did get clogged it should be easier to clean out.
10-20 acres can generate alot of water. Since it sounds like you have a deep ditch a bigger culvert would be better. Bigger than you need is better than not enough culvert. You might want to contact you county extension office and see if they can give you some guidence to size the culvert. 1 inch of rain on 10 acres is alot of water....
Later,
Dan
/ Culvert Advice -- Plastic vs. Galvanized ? #3
I'm a long way from being an expert here but with the weight on the MH (possible 8-9k# on the rear axle) and not knowing anything about the "dirt" I'd be a little concerned whether the plastic culvert could handle the stress. Does the galvinized steel have spiral flutes? This adds to the strength considerably. The trade off is that somewhere down the road the galv/steel may rust out as zinc is water soluable.
As for the grate, on a 24" culvert one might not be needed depending upon what gets washed down the gully. With a grate you could find yourself having to clean at least once a yr. I'd do some asking around from others in the area that have done it both ways and see what their feeling are.
Up the road a piece at MP #272.
/ Culvert Advice -- Plastic vs. Galvanized ? #4
Plastic is better than metal for several reasons. First, it will never rust out on you. EVER. Second, get the type with the smooth inner wall. It stays cleaner and doesn't hold silt and debri. As for strenght, both rely on preasure from the fill material being equal on all sides. You need a certain amount of fill on top based on the size of the pipe you install to reach maximum strength. For an RV, you will need this. For a car or light tractor, the amount on top isn't as important.
Since you want to create a crossing over a ravine, go as big as you can. That ravine was created by allot of water. The size of it shoud tell you the amount of flow you have to deal with. 24 inches is a huge pipe and should be able to handle most situations, but there is a reason they make bigger pipes and/or install two side by side.
Putting grates in front will cause more problems than it would solve. Small leaves will wash right through it, but with a grate in front, they will create a dam. It's very rare to see one along highways or anyplace that they are put in profesionally, so I'm thinking you don't need one. I don't have any on mine and so far haven't had any issues.
Backfill is usually with clean soil, but sometimes sand is used instead. Rock isn't any good because of the voids and dificulty in getting it all compacted. At the entrance to the pipe you will need to put something down to stop erosion. I've used sacks of cement for this with good results. Of course, it's not as attractove as rock. If you use rock, be sure it's big enough not to wash away or let the water through it. Small rock is useless during a heavy storm.
And always plan for the very worse that can happen.
Eddie
/ Culvert Advice -- Plastic vs. Galvanized ? #5
I am with Eddie. Go as big as you can. 10-20 acres draining thru a 6' or 7' deep ravine can be a lot of water. And you want it to go thru the culvert, not over the top.
And as Eddie said, don't use loose rock or gravel for fill. You don't want the water seeping around the sides of the culvert.
I have a 24" culvert in the ditch coming in off the road. I had to have some fill dirt hauled in but it was similar to what I have on my land. Once it is filled and packed, the circular nature of the pipe is very strong. Weight on top tends to push the dirt down around the sides of the pipe. That applies extra pressure to the sides adding support to the top. Due to the depth of my ditch, I have only about 1' fill on top of mine. But when I built my metal building, they brought in all materials on a flat bed semi. No problem at all driving it over the culvert. Oh. mine is metal.
/ Culvert Advice -- Plastic vs. Galvanized ? #6
I used plastic. Check out this pic of my culvert in it's early life. This was four years ago and all is well to this day. Plastic is lighter, easier to handle, won't rust, cheaper and by getting the double wall you won't have mosquito problems (it's smooth on the inside).
I've since added landscape block endwalls which really dressed it up /forums/images/graemlins/smile.gif
/ Culvert Advice -- Plastic vs. Galvanized ? #7
I guess I should have added that the strength of the culvert isn't in the pipe itself but in the soil around it. For either steel or plastic to work well you need enough material on top (at least six inches but a foot is better) and it should be well packed all the way around.
And of course, be sure to post pics before, during and after your project /forums/images/graemlins/smile.gif
/ Culvert Advice -- Plastic vs. Galvanized ? #8
Or just use both. The pic shows a 24" CPEP (smooth PE inside, corrugated PE outside) beside a 36" CMP pipe. Both full 20' sticks. I wanted plenty of flow through the flat bottomed channel. I scrounged these pipes or they would have both been CPEP. It is just a better material. You can cut it with a chainsaw, clip two together with these zip tie connectors, it is lightweight, won't rust, is cheap, etc.
2' burial depth with CPEP or CMP for full H20 loading. 3' with PVC, and one foot with ductile iron. H20 is the standard for most every road and bridge.
/ Culvert Advice -- Plastic vs. Galvanized ? #9
RobS - Your thought about the smooth inside walls of a double wall plastic culvert eliminating a mosquito breeding site really caught my attention. That thought had never entered my mind but it definitely is a factor in deciding galvanized versus plastic in my opinion. Thanks - Clyde
/ Culvert Advice -- Plastic vs. Galvanized ? #10
<font color="blue">
Putting grates in front will cause more problems than it would solve. </font>
No doubt in my mind that Eddie's words are true! Don't ask me how I know... /forums/images/graemlins/blush.gif
However, my experience is that you can get a similar benefit from some kind of grating that is placed AHEAD of the pipe opening, to catch debris that might block the pipe entrance.
In my case, I have an 18" pipe that goes a distance, then drops 45 degrees, and then goes about level again. I certainly did not want some sticks to jam up in there and plug the pipe, so I put a grating made from a couple pieces of rebar over the front of the pipe...
Well, a stick jammed in there, then some leaves, then some other stuff, then gravel and then it was totally blocked, so the water ran over the top and eroded out a bunch...
When I saw what was happening, I got in the ditch, scooped out some of the blockage at the pipe entrance, started flow into the pipe, pulled out the sticks, and let all the stones, gravel and small pieces wash down through the pipe.
Lesson I learned was to put a grating in the ditch about 20 feet or more from the pipe entrance. Bad stuff is caught there, and when the grating startes to block up, the overflow still runs through the pipe carrying the small stuff with it.
You can clean out the ditch at your convenience, and not worry...
The larger the pipe, and the shorter the pipe, the less the worry. I have about 100' of 18" plastic pipe, corregated on the outside, smooth on the inside. Good stuff for all the reasons mentioned above.
I do need something to catch potential pipe blockers...and my grating in the ditch seems to be the winning solution for me... /forums/images/graemlins/cool.gif
/ Culvert Advice -- Plastic vs. Galvanized ? #11
Plastic, double walled, corrugated, smooth bore pipe was the first thing that we put down in the culvert after we acquired our property 7 years ago. There has been much traffic across it including all the heavy equipment that was brought in to build the pond. Excavators, dozer's, compactors, and an endless procession of trucks. I check the pipe on a yearly basis to be sure that it isn't filling with silt and it looks to be in the same shape as it was 7 years ago. Think I'm getting my moneys worth on that expense.
Thanks for all the replies.
I was already leaning toward plastic based on corrosion, the mosquito abatement is another benefit.
Then I called the only two local suppliers & got the bad news.
One is out of stock on plastic culvert, and the other doesn't carry anything larger than 12", and is also out of stock on plastic. Of course no one will order this for me, since I only need one piece. Fortunately the one that does have 24" galvanized is also the lower priced one.
I will try calling the two suppliers in Medford (30 miles) and see what they have tomorrow. An extra hour of driving is worth it to get the better product.
If they don't have plastic, it looks like galvanized is going to be the only choice. Oh well, the country survived on galvanized culvert for a long time & if I get 30 years out of it, it will outlast me...
Another question;
How do I compact the dirt near the culvert? Do I need to rent a compactor (which is not a lot of fun to run) or can I just push down hard with the FEL after dumping each load? I have a Deere 110 TLB which weighs 8000 lb and can easily lift the front end with downpressure from the bucket.
I am thinking that if I get to this while the dirt is still wet from the winter rains, both digging and compacting will be easier.
I seriously doubt that I want to try driving on the dirt to compact it, the gully will be wet, soft and steeply sloped. Softer at the bottom too. Driving parallel to the partially backfilled culvert will be a great recipe for a lay-over. Not only would it be bad for me & the backhoe, but it would probably squash the culvert too.
/ Culvert Advice -- Plastic vs. Galvanized ? #13
Yes, you can do it with your tractor. Do it in stages. Add fill, pack it, add fill, pack it,........ Once you get it filled somewhat above the culvert, then you can run parallel to the culvert just at the edge of it and pack the fill down along the sides of the culvert. Then add more and pack by driving back and forth all over the crossing.
If the slope is steep, you may have to use some fill to build a temporary ramp to get up and down until you get it filled. Then take the ramp out.
/ Culvert Advice -- Plastic vs. Galvanized ? #14
If you are going to have 3-5 feet of fill over the pipe you are going to have a very narrow road on top of it, with that amout of fill I would go with at least 30 feet of pipe. I would go with a double walled plastic pipe.
/ Culvert Advice -- Plastic vs. Galvanized ? #15
I was thinking the same thing as SWinTexas that 3 to 5’ of fill is going to narrow that road bed by the time it tapers in. Motor homes are kind of wide and if the approach requires a turn you could be too narrow.
MarkV
/ Culvert Advice -- Plastic vs. Galvanized ? #16
From your basic description, it appears you are going to need 30-40 yards or more of fill. Did you get anywhere near that much from your excavation?
And I would agree with the 30' pipe. I would rather have a nice gradual slope on each side rather than a steep one. On second thought, do it like txdon did. /forums/images/graemlins/grin.gif
/ Culvert Advice -- Plastic vs. Galvanized ? #18
Listen to the advice your've recieved and get the plastic culverts.
You need to find the right suppliers. Every area will have a somebody with plastic culverts. They are used too often not to have them. Lowes hase 15 inche ones here, but the plumbing supply house has 24 inch in stock and I can go to the feed store and get 48 inch. You need to check around more.
Five feet of fill above the pipe will give you a road ten feet wide with 12:12 slopes. That's too steep and it will erode on you, not to mention the road is too narrow.
You can get 24 foot long culverts, but it's still not enough.
So now you need to get two 20 foot culverts and join them together. There are sleeves that slide right over the plastic that are real easy to install. The metal ones are a real bear if you stick with the metal culvert.
If you have five feet of fill over a 24 inch culvert, the simple math says you have a 7 foot ravine. How much water does it handle in the worse case storms???
24 inches might not be enough. /forums/images/graemlins/confused.gif
As for getting the fill material compacted, you have several routes. The pros will do it in lifts with a hand operated thumper or the bucket of a backhoe or trackhoe. Most do it yourselfers will just dump the dirt, smooth it out and drive over it. In time this works pretty good, but I wouldn't try paving the road because it will settle a little over the years. Gravel will work after awhile, but I'd hold off on that for awhile too.
I like the ramp idea to get down there close enough to work, then build up the dirt in layers and driving all over it.
Eddie
/ Culvert Advice -- Plastic vs. Galvanized ? #19
smooth bore, double lined corrugated is the way to go... That is all we used on the highway dept... Properly laid down, and with rock headwalls on each end, they hold up tremendous amounts of weight without a thought about it.... If you cannot buy 18", ask your local highway dept. We use to get pipe all the time for the locals,, We would order and buy and the people would go to town hall and pay the invoice to the treasurer, It would then revert back to our highway budget. Not all dept's will do this, however, it is an option you can ask about
/ Culvert Advice -- Plastic vs. Galvanized ? #20
The most important place to compact the material is around the bottom and halfway up the sides. Some will call this the springline. By compacting the soil well halfway up, the rest of the pipe acts as an arch to support the weight. Plus gravity will help compact above the half way point. Set the culvert down on a firm base, dump 6" of fill around the sides and get in there with your feet and maybe a sledge hammer and tamp it down around the bottom of the pipe and upwards. Do this at least half way up but be careful not to push material under the pipe and squirt it up and out of your trench.
With that much cover you shouldn't experience pipe collapse due to weight but you will experience settling if you don't compact the fill around the pipe. Plus if you don't seal the culvert well enough you may get water flowing around the culvert and washing away your backfill.
In the picture I posted the ravine is at least 7' deep. To get a decently wide roadbed you can actually drive down into the ravine meaning the road has a dip. This is beneficial in a few ways. One, you provide an overflow within the same ravine should the culverts plug. Yes it will ruin your road but the water is still in the channel. Two, the roadbed can be wider. And three, you won't have to haul in 40 yards of fill.
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2007 CRYOGENIC VESSEL NITROGEN TRANSPORT TRAILER (A67714)
2007 CRYOGENIC...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2017 Kenworth T880 T/A Galbreath Roll-Off Truck (A66736)
2017 Kenworth T880...
2017 Ford Transit 250 Cargo Van (A66736)
2017 Ford Transit...
1995 TIGERCAT 726 FELLER BUNCHER (A65056)
1995 TIGERCAT 726...
