BX Hydrostatic seal leak
/ BX Hydrostatic seal leak #1
k8ny
Shenandoah Valley
BX2200
I have a 2001 BX2200 with approximately 350hrs. It developed a hydro leak last year. I took it to my original dealer, he power washed it and ran it, couldn't find a leak.
1 week later the leak was there, guess it started to accumulate again. It leaks only dynamically and does not leak statically so only when it is powered up does it leak.
I took it another dealer in Virginia and they just called today. Seems like it is the hydrostatic pump housing seals and with parts and labor they want $893.00 to repair. I asked the dealer if there was a service bulletin on this and he said "No". Seems odd that with around 300 hours, the seals would go. He is ordering a Hydrostatic pump seal replacement kit to replace all seals (drive line as well) while he has it apart.
My question: Anyone had this problem with their BX2200 or 1800 or any BX? If so, has there been any sort of Service Bulletin on this? Also, is this price "in the ball park"? At 60/hr for labor I am guessing that labor is about 13 or 14 hours...that seems to be a heck of an amount of time! I have nothing to gauge this by so I am posting the questions here.
Thanks folks
Bob
/ BX Hydrostatic seal leak #2
I have a bx2200 I just started looking at the leaks and I too have a lot of leaks around the hydro unit and was wondering what ever happen with your leaks . Thanks jason
Thanks folks
Bob
/ BX Hydrostatic seal leak #3
Sounds like seeping. Little enuf not to worry, but gauge consumption. Seals probably dry from lack of use. Run the tractor.
larry
/ BX Hydrostatic seal leak #4
Its a good leak not just seeping , its a steady stream . it has almost 1600 hours on it. All it ever did was mow before i got it . i put the 3 point hitch and front end loader on it. i have the tractor tore down in the back and its not what i installed for the loader its coming down the pass side of the hydro pump area in front of the rear trans axle .Thanks jason
larry
/ BX Hydrostatic seal leak #5
/ BX Hydrostatic seal leak #6
seems to be leaking around 320 or 20 area in the pic .
/ BX Hydrostatic seal leak #7
My BX24 was leaking around the shaft where 120 130 are. Hydrostatic input shaft. $960 with driveshaft boots replaced at the same time.
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
Skid Steer Trailer Mover (A65640)
Skid Steer Trailer...
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
2014 Ford Expedition SUV (A64557)
2014 Ford...
ATS Mini Excavator ATS - ME18 (A66285)
ATS Mini Excavator...
(2) New 14-17.5 NHS tires on John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
