dodge man
Super Star Member
I’m not sure how many hours on these blades, maybe 300 to 400. The left blade of the three was worn the most, I’m not sure why?
There is only one correct way; getter done.I'm right handed but turn mostly left
Too much NASCAR in my youth?
Discharge is on the right turning left avoids blowing the cuttings into the next path. I'm sure that will get me a lot of corrections, but that is my method![]()
You got a mower on the excavator now?Good reminder @dodge man
My rear finish mower has been leaving a less than perfect cut in some conditions it should have no problem with. Need to crawl under there and check out the blades.
Not sure what you mean? But I have several mowing appliances. Including a bush hog for my excavator. The bucket is on right now. I was referring to a 6 foot Land Pride rear finish mower I use behind a Kubota B2601. Which is my favorite mowing weapon.You got a mower on the excavator now?
Desert eagle have you been mowing in the concrete blocks.? Never see anything like that before Only you really knowHey, even your old blades are like new! Here's what old and new looked like when I changed mine. What caused the jagged edges on the old blades is what I can't figure out!
Sand.Hey, even your old blades are like new! Here's what old and new looked like when I changed mine. What caused the jagged edges on the old blades is what I can't figure out!
That makes sense...given that I'm mowing about 50 acres of desert - pockmarked by dirt mounds from ground squirrels, gophers, and badgers.Sand.
Saw the effects of sand on mower blades in S. Florida. Virtually every operator has to wear goggles while mowing due to blowing sand, and most wear long-sleeve shirt, even in 90° weather.That makes sense...given that I'm mowing about 50 acres of desert - pockmarked by dirt mounds from ground squirrels, gophers, and badgers.
oes sand do that? Who would have thought itSand.
Sand.
