New blades today.
/ New blades today. #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I’m not sure how many hours on these blades, maybe 300 to 400. The left blade of the three was worn the most, I’m not sure why?
/ New blades today. #3
If you are right handed you probably turn right the most, making a longer turning radius for the left side. Fact or fiction, I don’t really know but it does add up
/ New blades today. #4
I'm right handed but turn mostly left 🤔
Too much NASCAR in my youth?
Discharge is on the right turning left avoids blowing the cuttings into the next path. I'm sure that will get me a lot of corrections, but that is my method :cool:
/ New blades today. #6
There is only one correct way; getter done.
Which way I turn my ZTR depends upon wind direction.
Dodge man, I don't need a mulcher or bagger. I use Gator Blades, they chop up everything small enough it disappears quickly, kinda spendy though @ $60 for a set of three blades, but they do last 4-5 years.
/ New blades today. #7
Good reminder @dodge man
My rear finish mower has been leaving a less than perfect cut in some conditions it should have no problem with. Need to crawl under there and check out the blades.
/ New blades today. #8
You got a mower on the excavator now?
/ New blades today. #9
Not sure what you mean? But I have several mowing appliances. Including a bush hog for my excavator. The bucket is on right now. I was referring to a 6 foot Land Pride rear finish mower I use behind a Kubota B2601. Which is my favorite mowing weapon.
I have never needed to sharpen the blades on the excavator bush hog with the low hours I put on it. Also, the nuts are welded on. So I am not looking forward to grinding those welds off and flipping the blades and re-welding when the time comes. I try to keep it out of the rocks - LOL!
Here is the excavator with the bush hog in action if you want to see it working.
/ New blades today. #10
Hey, even your old blades are like new! Here's what old and new looked like when I changed mine. What caused the jagged edges on the old blades is what I can't figure out!
