12VDC 6-way hyd. selector valve
/ 12VDC 6-way hyd. selector valve #1
kabong57
Wenona,IL
8260 NH, 1532MF, YM2000 Yanmar, 930 Case,
Has any one used any of these lower cost valves ;
or some thing else? Need to split the bucket roll-back circuit to control a grapple.
Not sure compared to the $200.00 Name Brand ones on the market
/ 12VDC 6-way hyd. selector valve #2
I would rather deal with a hydraulic supplier like Surplus Center, Discount Hose, etc.
You'll need more than just the control valve, you'll need hoses, couplers and fittings which they can help you with.
/ 12VDC 6-way hyd. selector valve #3
Since plumbed into curl -dump should work fine but pay close attention to see if there is any mention of the coil being polarity sensitive.
Like Fuddy stated you will also need a source for hose and fittings.
I'm very familiar using these valves on our AG equipment.
https://www.ebay.com/itm/387273575258.
I make all my own wiring harnesses and have access to fittings and hoses. Just thought the style I posted would be less bulky
and easier to install on a Compact tractor.
