Kiowner
- Joined
- Feb 15, 2026
- Messages
- 63
- Location
- New Hampshire
- Tractor
- Kioti 3520SE Cab, Kubota L5740 Cab, JD X540
First of all, with the PTO engaged and I increase the engine RPM's will the PTO RPM's also increase? IF not, how is the PTO RPMs governed to 540 RPM?
Next, my CX3520SE has a 540E and a 540 mark on the tachometer. It is my understanding that at the 540E mark it will run the PTO at 540 RPMs at a lower engine RPM. At the 540 mark the engine will run at full rated RPM speed for 540 PTO. How is the gearing ratio changed between these two PTO RPM options? With PTO engaged at 540E and I increase the engine RPMs to the 540 tachometer mark will the PTO gearing change to maintain 540 RPMs on the PTO?
