Quick Hitch woes
/ Quick Hitch woes #41
Pats is a bolt on euro is weld on.
Pats is a round pin in a square hole euro actually has a round hole.
So the benefit of pats is you don't need to weld, or buy bushings.
The benefit of euro is it's better designed and built like an OEM part in service (probably because almost all OEM's use them for Europe).
/ Quick Hitch woes #43
And the Euro hooks retain the ball joint which is essential on a 3 pt hitch system, since it has to move and pivot in so many directions.
Yes, it's more work to weld them on but it's well worth it. Lots of people have done it in the forum and say they don't want anything else, even after using Pats and other systems.
/ Quick Hitch woes
I saw something about that, but am having trouble envisioning. Do you need to get a set for each implement? I tried looking for info on YouTube but even putting in "Euro style" all I see are the conventional US type and Pat's.
/ Quick Hitch woes #46
Basically, you put the balls on the lower pins of the implement. Then you just need to back up to the implement with the hooks below the pins, then lift and it latches in place. Finally, you hook up the top link and PTO/hydraulic hoses if needed. Don't forget to raise the stand if the implement has it. Don't ask how I know it. 😅
You don't technically need a set of balls for each implement as you can swap them around but it's definitely more convenient and they're fairly cheap that might as well just get a set per implement.
I have 3 sets for 5 or 6 implements. 2 sets stay in the tiller and brush cutter all the time. I even replace the lynch pins with bolts since I don't have to remove the balls and this way brush won't pull the lynch pins either. The 3rd set is the one I keep swapping for the other implements that get ocasional use. Eventually I may get or machine at least one more set of balls.
"Lower link hooks" is probably the more accurate name of it. The "Euro" probably stuck somehow because it's way more common here in Europe. Even most tractors come with it as standard.
Here are a couple of videos from members from this forum on the subject:
/ Quick Hitch woes
Very helpful, thanks.
/ Quick Hitch woes #48
Does anyone read????
He already said they he has tried Pats EC on his machine and they did not fit.
And running with the extendable ends extended is a bad idea. I don't think any of them were meant to be operated that way. It's an "ease of hookup" feature only. If it never does any actual work you might never have an issue.
It seems the "cheap" implements or the old ones are primarily what aren't quick hitch compatible. However everything I have is now. You will see some implements advertised as "quick hitch" compatible as well. Usually a quick look at the way the top link connection is designed will tell you if it's compatible.
/ Quick Hitch woes #49
I suggest replace the QH hook bolts, with slide in pins. This will let you use the hook upside-down to attach that too high implement.
kimg1766rqh-toplinkpins-jpg.475243
(This photo also illustrates the tabs I added to the towbar, to keep the trailer ball upright. Those tabs are welded to sleeves, and bolted down at the inner and outer sides of the lower hook.)
And - The Speeco replacement top hook has its bolt holes offset. This is the solution when the implement crowds so close to the QH that the original hook won't engage.
20190125_161332rqg-speecohook2-jpg.603426
/ Quick Hitch woes #50
Yes, I was massively simplifying it.
The Pat's isn't quite square either.
/ Quick Hitch woes #51
These are also available from KBOH.
