MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,204
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
I still don't see any solar that is approved to be grid tied through a plug in the wall..
No. You can read it for yourself.I still don't see any solar that is approved to be grid tied through a plug in the wall..
Can you point out what number in the .pdf you are basing your argument on?
I did. I even ran it through AI...Nothing about plug in solar devices and the code being ok with bootleged devices that go from solar to the grid via a plug. There is language about solar generators.No. You can read it for yourself.
That just means the inverter has to be subject to UL1741?The Grid-Tie portion is line 88 and 89
88 (b) has been designed, tested, and certified to UL1741 and installed and operated in
89 accordance with the latest revision of IEEE1547, as amended.
However, that does not cover issues with:
1) overloading a house circuit (typically 15 or 20 amps) with both power from the Circuit Breaker Panel AND the backfeed amps.
And
2) Trying to backfeed through typical GFCI (Ground Fault) plug on a "balcony."
Summary -- this is all still rather: Half-assed and Half-baked.
Not bad, just not fully engineer-ed . . . yet.
…and some people have TOO MUCH MONEY! Hmmm…That looks like a bad idea from every angle imaginable.
People need to stop being so damn cheap, cheap to the point they will burn down their own place or kill a lineman.
If you are going through the time, effort and money of doing solar, do it right. The extra steps are not that much harder and it's not a home brew, backwoods hack job.
Seems like your AI hallucinates a LOT!I did. I even ran it through AI...Nothing about plug in solar devices and the code being ok with bootleged devices that go from solar to the grid via a plug. There is language about solar generators.
Maybe you attached the wrong article?
Key Points of the Document (HB0340 - Solar Power Amendments)
General Description:
This bill modifies Utah's legislation on residential solar energy by introducing provisions for portable solar generation devices.
Key Provisions:
- Definitions and Scope:
- Introduces the term "portable solar generation device," defined as a moveable photovoltaic device with a maximum power output of 1,200 watts, designed to connect to a building's electrical system via a standard 120-volt outlet.
- Excludes portable solar devices from the definition of "customer generation system."
- Exemptions for Portable Solar Devices:
- Exempt from interconnection requirements and agreements typically required under Sections 54-15-103 and 54-15-106.
- Not subject to net metering program requirements.
- Safety Requirements:
- Portable solar devices must include a feature to prevent energizing a building's electrical system during a power outage.
- Liability Protections for Electrical Corporations:
- Electrical corporations are not liable for damages or injuries caused by portable solar devices.
- Customers using portable solar devices are not required to:
- Obtain approval from electrical corporations before installation or use.
- Pay fees or charges related to the system.
- Install additional controls or equipment beyond what is integrated into the system.
Affected Utah Code Sections:
- Amends Section 54-15-102.
- Enacts Section 54-15-601.
Effective Date:
- The bill takes effect on May 7, 2025.
Financial Implications:
This legislation aims to simplify the use of portable solar devices while ensuring safety and reducing regulatory burdens for consumers and electrical corporations.
- No money is appropriated in this bill.
What is too much?…and some people have TOO MUCH MONEY! Hmmm…
I guess if you don’t know, you don’t know. Check with your AI.What is too much?
If you're that cheap, you wouldn't buy solar panels.Hey! I resemble that! I'm known as the cheapest man anyone has ever known!
I did read a bit about those panels and they are low power and not able to run a hair dryer.
(But I'm bald anyway)
They say the cost return takes about 10 years.
If someone made a really inexpensive EV you could charge with it I'd be interested. Maybe mount one on the roof.![]()
Yes, it is. There is a UL standard for anti-islanding that is required in every jurisdiction i have ever experienced. If verifies that the device will disconnect from the grid if the grid power goes away. If an inverter isn’t listed for that UL spec then it’s illegal to connect it to the grid. Don’t buy it. Sorry, I don’t recall the UL number off hand.It's code to plug panels right into the grid via a plug from an inverter?
Find that accepted code...
No but this local generator backfeed event fits the scenario exactly and many would have died from the hit he took.And I know it's a touchy subject, but can anyone find ONE instance of a lineman being killed by a backfed generator?
I found ONE years ago. I found ONE today, but it was a 480V generator.
