Snobdds
Super Member
Rabbit season.
Do they have a plug too?
Rabbit season.
Again, it's not an easy way hillbilly solution. It's accepted code in europe and in Utah it's accepted with UL listed devices.Maybe because people know how to prevent from doing it. An electrician can lose their licence if they hook it up wrong. Logical explanations are usually the best.
That may change with an easy way hillbilly it.
Easy for the rich guy to say. I like to call it being frugal and to do frugal well you have to be smart. I do agree being dumb AND cheap is a bad combo.
Hey! I resemble that! I'm known as the cheapest man anyone has ever known!You have a lot of faith in the electrical skills of a cheap person.
I did read a bit about those panels and they are low power and not able to run a hair dryer.
(But I'm bald anyway)
They say the cost return takes about 10 years.
If someone made a really inexpensive EV you could charge with it I'd be interested. Maybe mount one on the roof.![]()
Not killed but I have treated a lineman in the ED that was shocked by a generator back feed. Line was dead when they first started working on it. Somebody fired up a generator without back feed protection about an hour into the repair.And I know it's a touchy subject, but can anyone find ONE instance of a lineman being killed by a backfed generator?
I found ONE years ago. I found ONE today, but it was a 480V generator.
Personally I can't see myself buying one...but kudos to those improvements in solar panels.How loud is your squeak when you walk, the louder the squeak the cheaper the person. I know a few that I can hear through the internet.
So I guess if they are so low power, what is the point of them again?
Found where the references are being sourced...AI, which is scrubbing from Reddit.
Key Aspects of Balcony Solar Systems:
- Installation & Components: Systems usually consist of one or two panels connected to a microinverter that converts DC power to AC for immediate home use.
- Easy Setup:
No complex installation is required; they can be fastened to balconies and plugged into a standard wall socket.
- Effectiveness: While they cannot power a whole home, they can cover a portion of base-load electricity consumption, such as refrigerators or electronic devices.
- Safety & Regulation: In the U.S., regulation is evolving. Utah was the first state to allow them, and Virginia is the second. Others are introducing similar legislation. Using UL-certified microinverters with anti-islanding features is crucial for safety.
- Legality: Outside of specific, progressive states, installing these may conflict with local utility regulations. However, in Europe, they are popular and widely approved.
- ROI: These systems can offer a 3-5 year return on investment
Typically FREE solar power is a myth. The equipments effectiveness diminishes as it ages so you end up paying for the some expensive equipment until it is no longer effective and needs to be replaced with more expensive equipment...in my opinion
Realize that little balcony solar panel we're talking maybe 800 watts while a car battery is 10 times that. Has anyone here ever had a wet wash mitt on and had it touch the positive while other wet hand is grounded?
We're not talking about a 10+kW generator here. Any lineman is going to check for power before reconnecting anything.
Thank you!Not killed but I have treated a lineman in the ED that was shocked by a generator back feed. Line was dead when they first started working on it. Somebody fired up a generator without back feed protection about an hour into the repair.
It's code to plug panels right into the grid via a plug from an inverter?
Find that accepted code...
Won't work with the balcony solar setups because it takes 110V from the grid to activate the inverter. Grid goes down, no balcony solar.Besides the "free" electricity, battery backup enables the solar panel system to keep on working when the grid is down - priceless for me in PGE (Part-time Gas & Electricity) territory in Norcal territory, especially being on a Squirrel Fart feed. (If a squirrel farts anywhere near a line, safety features cut power.) I'd have to grow more hands to count my grid outages on my fingers.
