Wagtail
Super Star Member
- Joined
- Jan 15, 2013
- Messages
- 13,453
- Location
- St Helens, Tasmania, Australia
- Tractor
- JD 4105 / JD Z355E (48" deck)
There, and quite a few other places too, Mate.In the UK... maybe.
That sounds like a useful tool. By your description, I have seen somewhat similar shovels in the UK and Commonwealth countries, but not here. I had forgotten about them, and now I'm thinking they would be great for digging out my rounded driveway gutters. Hmmmm. Thanks!I had a ditch shovel that was made like the mfgr split a thin 8" pipe lengthwise, welded an arch in the middle with a place for a handle on the top, and a standard long handle there. This arch was made to swivel and set to any angle so the user could either pull or push the " shovel along to make a round-bottom ditch.
I had used it at my FIL's place while getting it ready to sell and left it there.
Someone else liked it so took it.
I've never been able to find another or any reference to it on the internet.
It was great for cleaning out small ditches.
Anyone ever heard of something like that "shovel"?
That sounds like a crumb shovel. It's used to remove the crumbs at the bottom of the ditch following an 8" wide trencher digging a deep trench for water, gas, sewer, etc.I had a ditch shovel that was made like the mfgr split a thin 8" pipe lengthwise, welded an arch in the middle with a place for a handle on the top, and a standard long handle there. This arch was made to swivel and set to any angle so the user could either pull or push the " shovel along to make a round-bottom ditch.
A handyman "let" me use his one summer in 1979 when I built my garage with a frostline footing dug with an 8" trencher.@bigtiller Love it! I had never seen one before, and boy could I have used one on more than a few projects...
All the best, Peter
My dad has that shovel on the right. He calls it a "diego" shovel. Not sure if that was the correct name or brand name. It could have also been a slang term. Used in narrow trenching. I have bought the one on the left years ago. Jon![]()
All the best,
Peter
Yep, That's it! Thanks, I've searched the internet for several years without success.That sounds like a crumb shovel. It's used to remove the crumbs at the bottom of the ditch following an 8" wide trencher digging a deep trench for water, gas, sewer, etc.
like this?
The one on the left reminds me of a long handled 'pelican pick'.Or in the UK,
All the best,
Peter
I have only known it as a spade.My dad has that shovel on the right. He calls it a "diego" shovel. Not sure if that was the correct name or brand name. It could have also been a slang term. Used in narrow trenching.
It sounds and looks like a set of snap ring pliers.Here's one for the collective.
The jaws open when you squeeze. Dad said they were used for hog ringing, which doesn't make sense unless back then you had to open the rings first.
Modern versions are called Bow Opening Pliers and they're popular as a jeweler's tool, so...
Looks like they had a rough life.
Those two pliers are beautiful works of art...very elegant curves.The top pair of pliers are ones that my dad had for as long as I can remember, he probably got them at a sale, so they are from the 30's or 40's war surplus at the latest. The bottom pair showed up in the free box at a garage sale, covered in rust and unable to open without considerable effort. A few minutes with a wire wheel on the grinder and working a bit of oil into the joint resulted in a perfectly usable companion pair to the originals, whom they've got to be closely related to in age and manufacture.
I think this may be them. I have one of each.Those two pliers are beautiful works of art...very elegant curves.
They sure look like them, but I can't find any info given the numbers I have on one set. These are from the originals, can't find any numbers on the latest pair, even with magnifiers.View attachment 5336821View attachment 5336820
