Rake What could this be?
/ What could this be? #1
CutTheHolesOut
Bolens G274
Next to the rake is something on the ground. It looks to me like an old radiator for a house but I think it could belong to a tractor. Weights or something? Hopefully someone smarter than me will be able to recognize it. Thank you
/ What could this be? #2
It is part of an old boiler. It appears to be three sections joined together. The round plate on the right end is a tankless hot water heater coil. The square opening is the firebox.
Thanks. That was my gut feeling. Just sitting next to the rake made me think otherwise. I wasn’t able to get close enough to inspect it
/ What could this be? #4
It would make a great counterweight if you could mount it to the 3pt hitch.
How much would you guess it weighs? I could probably take it for scrap if it would be worth it.
/ What could this be? #8
I just replaced a boiler with 4 section that size. It weighed 700#, so I'm guessing that one would weigh 450 to 500#.
Around here scrap iron is going for $.20 / #, so maybe $100.
2013 Ford F-650 Ext. Cab Chipper Truck (A64194)
2013 Ford F-650...
IRANCH Tire Balancing Machine (A64194)
IRANCH Tire...
County Line 3Pt Chisel (A66408)
County Line 3Pt...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A64553)
2018 Takeuchi...
