B2150 Fails to Shut Down using switch
/ B2150 Fails to Shut Down using switch #1
JWR
Elite Member
So MD / WV
MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
I've seen similar threads before but not quite the same. [By the way I have 3 B2150's bought over the years and love the critters. This one in question happens to be in the best condition of the 3. About 1988 model, has only ~ 600 hrs on it. Great shape. ]
So here is the tale: Another family member had run down the battery after snow removal 270 miles from me at my vacation place. Left lights on. When I went there a month later it charged easily and started quite readily after maybe an hour of charging at 15 or 30 amp level. All indoors. However before charging I had tried the starter just momentarily with the charger on. Not using the "engine start" high current charger mode. The dash lights were bright but some relay or ? chattered loudly when I turned the key to engage the starter. Did NOT sound to me like the ordinary starter solenoid at all, a more "tinny" light duty kind of sound to it. I was not really trying to start it, just checking to see what adding 30 amps might do.
All went well after charging and starting (and running an hour or more) EXCEPT that now it will not shut off by key. The emergency shutoff pull-knob will shut it off but the switch will not. Also in the past when shutting down I would always hear some delayed relay click , kind of a light thunk, around 10 or 15 seconds after the engine was shut own. All 3 of my B2150s act that way. Do not know what that is (fuel solenoid?), but now when stopping the engine by the pull knob there is no “later relay noise.”
I assume some relay or solenoid has been blown? Does it matter to have to shut it off with the pull knob for a good long procrastination period until I get around to debugging the issue? Is that risking some sort of damage?
/ B2150 Fails to Shut Down using switch #2
It sounds like you have a good idea what the problem is. I would be checking the fuse or relay that controls the fuel shutoff solenoid.
There is no penalty in manually shutting the engine down.
Low voltage or bad batteries cause a low voltage, high amperage condition that can cause problems. I recently changed my 10 year old battery that was cranking slower than usual after reading about a fried computer from cranking with a bad battery. Not an issue with your B2150 though.
/ B2150 Fails to Shut Down using switch #3
I had a B2150 and loved it. There is a relay that fires the fuel solenoid. I have had the fuel solenoids fail in both the open and closed positions on Kubotas. With the key in the off position you should be able to move the fuel solenoid by hand if not it has melted.
Good observations. Thanks !!
Do you know off hand where to find the fuel solenoid?
/ B2150 Fails to Shut Down using switch #6
Its mounted on the injector pump. Your manual shut off will connect on the pump where the solenoid connects.
  • Good Post
Reactions: JWR
/ B2150 Fails to Shut Down using switch #7
Heres the location for the complete manual.
Great response Alan. Appreciate your legwork tracking this down. It will be a while before I get back to where this tractor stays but at least now I know what I am looking for. And a measure of relief to know that it won't hurt to shut of the engine with the pull knob for a while.
/ B2150 Fails to Shut Down using switch #9
Check the fuse first - much easier.
gg
2014 FREIGHTLINER CASCADIA (A65643)
2014 FREIGHTLINER...
New 20' Container  (A62679)
New 20' Container...
Location (A65640)
Location (A65640)
HD Round Bale Feeder (A66408)
HD Round Bale...
New/Unused Landhonor Quick Attach Grapple Bucket (A65583)
New/Unused...
Landhonor Quick Attach Log Grapple (A66285)
Landhonor Quick...
