TC29D issue with parking brake light
/ TC29D issue with parking brake light #1
dqdave1
N. E. Ohio
tc- 29d
Replaced bulb as it was bad. Now light stays on always. Tried to adjust the switch, no difference. Removed switch, tested, tested good , but light is on even with switch removed.
Placed jumper in exposed plug to switch, no difference.
Anyone have a suggestion??
/ TC29D issue with parking brake light #2
Socket is being back-fed by something.
I was hoping someone had the same issue and figured it out.
I understand bulb is getting power but since it is a circuit board, may be chasing something impossible.
/ TC29D issue with parking brake light #4
Sounds like the circuit board..and a good time to just remove the bulb.
/ TC29D issue with parking brake light #5
Most times, a light like that turns on when the switch completes the circuit to ground. If the wire going to the switch is pinched or shorted to ground, the light would stay on all the time. Test the wire...is it grounded? I would trace the switch wire back to find where it is grounded. If not grounded, then there is something wrong in the controller.
Agree, has to be grounded to make connection. Not grounded at pigtail where switch plugs in .
Will have to pull instrument panel and see what I find there
Thanks for info.
/ TC29D issue with parking brake light #7
Thanks for info.
Going by this diagram...
https://www.tractorbynet.com/forums...ew-holland-tc33d-2-style-of-harnesses.468559/
...the wire goes from the switch to the inst panel. Check for continuity to ground from the switch wire at connector. You could use an ohm meter and have the key off. If it is grounded, unplug the connector at the inst panel and check the same wire. If it is grounded, you have a short. If not, the problem is in the panel.
12V YARD SPRAYER (A64278)
12V YARD SPRAYER...
2019 Ford Explorer AWD SUV (A64557)
2019 Ford Explorer...
2014 Club Car Golf Cart (A62613)
2014 Club Car Golf...
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2015 Global M3 Street Sweeper (A64556)
2015 Global M3...
2025 Swict 84in Bucket Skid Steer Attachment (A64553)
2025 Swict 84in...
