Hello from new member Schips.
/ Hello from new member Schips.
Welcome to TBN, List what you need to do and that might help with selection.
Moving firewood is very different from mowing or chopping down fields.
Good luck in your search.
Gonna get a loader, forks and a box scraper. Level out my yard, remove shrubs and fencing. Landscape after new fence put in.
Fairly level yard but dragged in a few hundred tons over the years and when house was waterproofed picked up additional soil.
As stated b4 wife wants land and planning for that if it happens.
I’m sure a JD1025e would suffice now…..
But if I find that gold nugget 35hp might not be enough.
Just saying…..
I got by with a 30 HP L2550DT Kubota on 77 acres for years until adding a IH 584 about 10 years ago.. It did a lot of work and continues to do so and shows it. 6700 hours at last check.
There are places for each tractor although probably 90% of my work is still done with the Kubota.
One piece of advice I have is whatever you get, protect it from the elements and follow or exceed the manufacturers maintenance recommendations. Grease is your friend. DO NOT let joints get dry or you will have issues.
If you get 4WD, only use 4WD when necessary to avoid undue wear and stress.
Keep the fuel tank full to avoid condensation in the tank and moisture in the fuel.
Do not test it to see how much it can haul. If you have any thoughts in that direction make two trips.
Where do you live?
Thanks for the advice. North east Ohio
Welcome Schips, what size (HP) are you considering? There are cutoffs for emissions based on hp. I have a L3901 which has a DPF, Diesel Particulate Filter. It’s recommended to run higher rpms to keep exhaust temps. higher, my tractor will go to regen maybe every 50hrs or so, never been an issue, just up the rpms and keep working until regen is complete 15-20 minutes. Maybe a small issue of I were ready to finish work for the day and the regen light comes on.
Mike
Thanks for advice, and yes fear of emissions is gone.
YouTube vid showed how easy to do.
So tier 3 tractors 35hp now in the loop.
And now dont need it but in case I do.
/ Hello from new member Schips. #24
Does anyone know if there is a list of WHEN all this pollution stuff started on all or most of the tractor brands? I believe that would be useful.
/ Hello from new member Schips. #25
I like the emissions stuff on my 3 yr old 3039r. I can start it up, attach the RFM without stinking up the shed for half a day.
My 13 yr old 2720 is just the opposite. It will stink up the shed for the whole day if I don't open up the overhead door to air it out.
/ Hello from new member Schips. #26
I have an MX5800 and L6060, both with DPF. No issues whatsoever in 2000+ hours. Regens occur every 40 to 60 hours and most of the time, I don't know it's happening. Personally, I wouldn't let emissions keep me from buying new.
If you don't abuse or store your tractor outdoors, you will likely get what you paid for it in trade. You don't necessarily have to buy your ultimate tractor now if you take good care of the one you have.
Bought a new Kioti 4520SE, free loader. Way more tractor than needed.
But still looking for land, lol.
/ Hello from new member Schips. #29
G'day Mate and welcome to TBN from Downunder.
Enjoy the site.
Sept of last year... sorry I missed you at the time.
Just ease your
Way into the project! ;)
lol, yup. I fully intend to remain free of the I think I can do it.
Great advice from folks here and YouTube vids are keeping me “grounded”
/ Hello from new member Schips. #31
25 hp is the limit where you don’t need emissions add ons. That stuff isn’t good, obviously anything can be a problem but if you need a bigger tractor I’d get what you need and not worry about it.
We need pictures or it didn't happen... ;);)
Where do you live?
Great information and thank you for it. Run rpm hot and no I don’t want to test the tipping point of my tractor.
Way, way, WAY, more tractor than I need. Still will put wheel spacer’s on it and wheel weights.
Not going into production so just enjoying the tractor
And the FUN in using one.
Thank you for great advice, will store indoors and over grease it along with additional PM.
Did buy way too much tractor for now…… just sayin.
Kioti DK4720SE.
/ Hello from new member Schips. #38
Question for everybody: with this Kubota what does one do if they decide they need a backhoe later? It's not a bolt/swap w/3pt addition like on my old B7100, I don't think?
/ Hello from new member Schips. #40
There are OEM frame kits that can be added to many Kubota tractors that allow for a backhoe. I managed to find one for my old B7100HST and added a hoe many years after I bought the tractor.
There are backhoe attachments that mount on the 3pt, but they are often difficult to use and can cause serious damage.
New Holland 273 Square Baler (A66408)
New Holland 273...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
8' x 6' Galvinized Shed (A66408)
8' x 6' Galvinized...
Frontier 10ft. 3 Point Disc (A65640)
Frontier 10ft. 3...
66in. Skid Steer Bucket (A65640)
66in. Skid Steer...
Caterpillar 318BL Excavator (A65579)
Caterpillar 318BL...
