Hello from new member Schips.
/ Hello from new member Schips. #1
Schips
Member
Deere
Hello all. New member, Schips here.
Quick question is the emissions on new tractors real headache?
Looking to buy first tractor and am planning on buying more than I need.
Thank you.
/ Hello from new member Schips. #2
Welcome aboard!
Emissions are reported as being a lot better than they were several years ago. Although I might not fear them now, I bought a used tractor at the end of 2019 to avoid them.
I like your mindset:)
/ Hello from new member Schips. #3
Welcome to the Forum! 👋
Can't help you with emission tractors. My newest is a 1986. :ROFLMAO:
/ Hello from new member Schips. #4
I personally try to avoid emissions but, the new tractors seem to be relatively trouble free with only minor inconveniences from DPF regens. I don’t know what size tractor and how much power you need but, emissions alone wouldn’t stop me from buying the tractor I want/need.
Mike
/ Hello from new member Schips. #5
Welcome Schips, what size (HP) are you considering? There are cutoffs for emissions based on hp. I have a L3901 which has a DPF, Diesel Particulate Filter. It’s recommended to run higher rpms to keep exhaust temps. higher, my tractor will go to regen maybe every 50hrs or so, never been an issue, just up the rpms and keep working until regen is complete 15-20 minutes. Maybe a small issue of I were ready to finish work for the day and the regen light comes on.
Mike
/ Hello from new member Schips. #6
I don't have one, my understanding is that you don't want to let them idle at low RPM. Run them hot with more PRM's (My tractor would be dead since I constantly let it run at 1000 rpm's...)
Mike
Don’t know yet on HP. My yard is a acre,
But every time we drive in the country Wife sez we need to move.
So instead of a JD 1025r I already am thinking a 3025.
Now from watching YouTube vids a HP of 35 or so goes up hills better.
And from reading threads here bigger is better.
Yeah a new tractor is not a deciding factor. Am willing to get a older one if it works for me.
/ Hello from new member Schips. #10
Over 25hp, I think you will find most tractors to have at least a DPF, unless you go older used. I can only speak for my Kubota, it’s not been an issue, but I only have 200hrs. On it.
Mike
/ Hello from new member Schips. #11
Welcome to TBN....enjoy.
/ Hello from new member Schips. #12
Though I live on 10 or 12 acres I only have about 2 cleared. My tractor is a 45 year old Yanmar YM2310. It has a front end loader (FEL), 27 HP engine, and 23 HP at the PTO. This tractor gets used a lot. The FEL is super useful and I made an extension for it that more than doubles the cubic carrying capacity. This enables me to load up a bunch of brush and tree limbs when cleaning up and transport the stuff to the burn pile. I have a 5 foot wide Yanmar tiller that I use behind the tractor as well as a 4 foot wide box blade and a post hole digger. The post hole digger gets used mainly for planting trees and other plants. Even if I had 4 acres cleared I don't think I would need a bigger tractor.
Eric
/ Hello from new member Schips. #13
Emissions are problematic if you want/need to idle regularly or run at lower RPM's. Newer units 2012 and up that have tier 4I and tier 4, don't like to idle and you need to run it like you stole it.
Personally I won't have any thing with Tier 4, my Bobcat is the last of the Tier 3's. However I have worked on several neighbors that have had emission problems. Some I can fix and other need to go to the dealer for computer work.
/ Hello from new member Schips. #14
I have not had any emissions problems so far in around 240 hrs on a 2850m massey ferguson but I don't let it idle for long periods. I owned a LS tractor that had DPF and did not have any issues with it either but I got rid of it to get the bigger massey ferguson. I would not let the DPF stop me from getting the tractor I wanted.
/ Hello from new member Schips. #15
I got by with a 30 HP L2550DT Kubota on 77 acres for years until adding a IH 584 about 10 years ago.. It did a lot of work and continues to do so and shows it. 6700 hours at last check.
There are places for each tractor although probably 90% of my work is still done with the Kubota.
One piece of advice I have is whatever you get, protect it from the elements and follow or exceed the manufacturers maintenance recommendations. Grease is your friend. DO NOT let joints get dry or you will have issues.
If you get 4WD, only use 4WD when necessary to avoid undue wear and stress.
Keep the fuel tank full to avoid condensation in the tank and moisture in the fuel.
Do not test it to see how much it can haul. If you have any thoughts in that direction make two trips.
Where do you live?
/ Hello from new member Schips. #16
After I got some hours on my new tractor, 3 yrs ago, it started to do a regen while I was working with it. Since the saleman, when I bought it knew nothing about it, I didn't know what to do. I quickly got the manual and read it. After that one time, it has never been a problem for me. If you run it at low rpms most of the time, it regenerates more often. If you keep the rpms up, those occur around 50hrs on my kubota, I just crank up the rpms and continue working.
/ Hello from new member Schips. #17
Regeneration on my 40 hp boomer is barely noticeable; happens every 50 hours or so.
For only an acre you might do better with a strong lawn and garden tractor. Save your bucks until you purchase the more acreage you're dreaming about instead of blowing it on more tractor than you currently need. Tractor dealers love it when someone comes down with horsepower disease.
/ Hello from new member Schips. #18
Welcome to TBN, List what you need to do and that might help with selection.
Moving firewood is very different from mowing or chopping down fields.
Good luck in your search.
Yeah I need a tractor now more than acreage, lol.
Just planning if the acreage happens.
Saving pop cans as we speak.
And dealers must love those that dont plan for the future.
Reading a post here about a lot of light implements that are hard to sell.
I go big on the first go, fix up the yard I terraformed with a shovel and wheelbarrow. Too old to do that anymore, lol.
New/Unused Landhonor Hand Chain Lever Hoist (A65583)
New/Unused...
2014 Club Car Golf Cart (A62613)
2014 Club Car Golf...
JOHN DEERE BD1108 GRAIN DRILL (A64277)
JOHN DEERE BD1108...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
2012 Ford F350 Truck (A62679)
2012 Ford F350...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
