Hyd hose length and bend radius
/ Hyd hose length and bend radius #1
650gSatoh
NJ
Satoh 650g-Sold...Kubota L2501
Hi Guys,
Im wondering if the hoses to my side link I'm installing look ok?
They are 1/4" hoses. I have moved the lift arms up and down and they seem ok but they are not filled and under pressure.
I think the valve on the cylinder is able to be loosened to rotate, which would give me a little slack. Has anyone rotated one of those and can tell me which of the nuts to slack off?
I got 4 hoses the same length and the 2 going to the top link are fine.
/ Hyd hose length and bend radius #2
Yes, you can rotate the check valve in the cylinder. Just loosen the nuts I marked in the picture, rotate the valve and tighten them again.
EDIT: Make sure you keep an eye on the hoses/fittings as you cycle the 3 pt hitch up and down, to make sure they don't hit anything.
Thanks for the warning. I did move it up and down slowly and stopping to check and will do the same when I connect the top link.
/ Hyd hose length and bend radius #5
your hose spec's will tell you based on how the hose was made / material used but usually about 10X the radius is the tightest for common discount type pre-made hoses. Your last pic looks tight.
Gotcha. Im going to rotate the check valve tomorrow and hopefully that will give me enough slack. Thanks.
The hose has a bend radius of 2".
  • Hose Type SAE 100R16 HydraLite II, Two-Wire Braided
  • Overall Length 36"
  • Inside Hose Diameter 1/4"
  • Outside Jacket Diameter 0.57"
  • Fittings JIC 6F, Swivel
  • Minimum Bend Radius 2"
  • Temperature Range -40° to 250°F
  • Working Pressure 5800 PSI
  • Burst Pressure 23200 PSI
Volvo EC55B Exvacator (A62679)
Volvo EC55B...
2018 Generac S/A Towable Light Tower (A64194)
2018 Generac S/A...
2013 CORPUS 40FT  T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
2011 Ford Fusion Sedan (A61574)
2011 Ford Fusion...
(APPROX. 54) 2X6X10.5 ROUGH SAWN OAK (A64276)
(APPROX. 54)...
