Loader Lowering valve picture
/ Loader Lowering valve picture #1
cabover4us
Back in Salem, New York
1987 john deere 855 sold and bought a YT235 Yanmar, love this tractor
This rotation valve under front of seat on my Yt235 2017 model I have for one never touched or adjusted. But I tried on other days previously and I can't move this hand knob either way. Would you say it looks backed off all the way because the blue color is showing? Anybody else with a, Yt235 can pop a, picture on here to show me the difference of screwed in and out? I just
don't want to break it off if I have to use some force to break it's seal..
It wants Write and Read, on storage permission to post, a picture.
How, do I grant permission on here?
/ Loader Lowering valve picture #3
That flow control valve under the seat adjusts the speed the 3 pt hitch lowers and if fully closed, it will lock the 3 pt hicht in place, preventing it from lowering. It can still raise at full speed at all times, regardless of this valve position though.
This flow control valve won't affect anything else in the hydraulic system. If not used frequently, it will seize over time and can be tricky to get it going again.
Here I deleted my old tractorbynet app and added it back in. So, I hope you can see Pic. Also thank you for clearing the air on what ackually the valve operates, the 3 point only I mistook the valve as to be also controlling the loader function.
/ Loader Lowering valve picture #6
On my 2 tractors turning that knob clockwise closes the valve locking the 3-point from lowering anymore.
From your picture, I'm only guessing here, it looks open to me.
Here's a picture of what mine looks like.
It ackually looks like it's unscrewed because in deduction if it was closed the 3 point wouldn't go down. Can you give me an idea as to how to twist clockwise should I add slight heat to base of housing where screw is inserted?
/ Loader Lowering valve picture #9
Spray some sort of lube on it and try to rotate using a wrench on that nut behind the knob to give you more leverage. Doesn't look like it's stuck too badly.
And yes, if it was all the way in, the 3 pt wouldn't lower at all or very slowly.
/ Loader Lowering valve picture #10
I personally wouldn’t use heat… start with a wrench on the nut farthest away from the plastic knob… turn counterclockwise just a smigeon… less than an eighth of a turn… move the wrench to the nut closest to the plastic knob and turn clockwise… FWIW, my Kioti use two different size wrenches for those fasteners…
Repeat a couple times if necessary… once you have it moving relatively easy, turn it completely out and put a light coat of anti-seize on the threads…
2020 CATERPILLAR 279D3 SKID STEER (A65053)
2020 CATERPILLAR...
2022 EZ-GO ELITE...
2016 John Deere 85G Midi Excavator (A64553)
2016 John Deere...
(UNUSED) GOODYEAR 28L-26 TIRE (A64278)
(UNUSED) GOODYEAR...
12in. Bucket w/ Teeth Excavator Attachment (A64194)
12in. Bucket w/...
2007 Toro Z-Master 72in. Zero Turn Commercial Mower (A64553)
2007 Toro Z-Master...
