Preventing split fingertips in cold weather
/ Preventing split fingertips in cold weather #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
My finger tips tend to lose oil and split any time I wash them frequently and especially in winter.
Here are the best preventative measures I've found:
Wearing disposable rubber gloves when mechanicing. The grease can be easily washed off the gloves with dish washing liquid while they're still off my hands.
When washing my hands with warm water I immediately cool them with cold water so the skin contracts and body oil isn't wiped off on the towel and doesn't evaporate. I can feel the pores contracting. To me, the thermal shock is worth not having stinging cracked fingers.
Less natural oil is rubbed out of my skin if I pat rather than rub with a towel.
After washing I use some type of moisturizer.
Any better suggestions are welcome
/ Preventing split fingertips in cold weather #2
The working hand cream dose wonder... if you are a naturalist, beaver fat dose wonder for arthritis and splint finger tips / dry hands, I heard bear fat is also really good.
/ Preventing split fingertips in cold weather #3
Sounds like you've got a good routine for preventing split fingertips. I also have had that issue, and still do occasionally. I use Bag Balm a couple times a day as well as a homemade tallow/olive oil concoction. When finger skin gets cracks I apply a smidge of triple antibiotic to the crack and seal with a band-aid wrapped with duct tape to prevent the adhesive from letting go when I wash my hands next. I also apply Bag Balm to my heels; I used to suffer from cracks in my heals so bad when I was a kid that I'd have to walk on the balls of my feet for half the winter.
/ Preventing split fingertips in cold weather #4
+1 on both working hands and bag balm. If it is cold and dry, I also try not to use water that is as cool as possible, and pat dry.
FWIW: I find that the NexCare waterproof bandaids to be a real help. If I put them on clean dry skin, they keep the skin crack or cut dry for a day or so, through repeated handwashings. I try to use the smallest possible ones on finger tips as nothing seems to seal well to the gaps around the edges of my finger nails. YMMV
All the best,
Peter
/ Preventing split fingertips in cold weather #5
This time of year, I carry a tube of O'Keefe's in my pocket.
/ Preventing split fingertips in cold weather #8
I use Nitrile gloves when mechanicing or working with goo. Toss 'em when done.
Taught to me at a very young age by my uncle, a career OTR truck mechanic: If you do have grease, oil, lead, etc. on your hands wash in cold water. Keeps the pores closed so the nasty stuff doesn't leech in to you.
Several years ago when I was whining about my painfully dry hands (and face) the missus got me a bottle of this. It's not perfumey and doesn't leave you greasy feeling. I now swear by it. Although so far the "age defying" part isn't working.
/ Preventing split fingertips in cold weather #9
I use a John Deere "Premium Hand Cleaner". It's made with soybean oil, green in color. I've never had cracked skin while using it. Canada part number is TY26069.
It's like a hand lotion that does an unbelievable job of floating the grease off. It's not cheap (approx $24 CAD for 2 us quarts). I get about a year out of 2 quarts so I don't mind the price. Plus I never get cracked skin from washing my greasy hands.
/ Preventing split fingertips in cold weather #12
This:
Then thin it with some alcohol (hand sanitizer) so it soaks in.
I think ManaPro (right) bought Corona (left) and changed the marketing and label.
Carmex is also the only thing I've found that actively stops and removes those cracks that just appear for no reason, like when using tools that rub and a crack opens up and just will not go away.
/ Preventing split fingertips in cold weather #13
Is bag balm also called udder cream? May be a regional thing I'm guessing.
From the internet...
Bag Balm and udder creams are both designed to soothe extremely dry, cracked skin, but differ in formulation and texture. Bag Balm is a thick, petroleum-based antiseptic ointment (99% petrolatum/lanolin), ideal for intense, targeted healing. General "udder creams" are often lighter, water-based, and better for daily, over-the-body moisturizing.
/ Preventing split fingertips in cold weather #14
After trying several brands of hand care products I asked my dermatologist. She said to buy a small bottle of 99% pure glycerin from any pharmacy and apply 5-6 drops to the back of each hand, then rub it in well. It will feel greasy at first but 5 minutes later it's soaked into the skin.
It is the least expensive and most effective product I've tried.
I apply it at bedtime and next morning the dry scaly skin is smooth and comfortable.
I got to comparing glycerin and name brand products. All the name brands contain glycerin in some low percentage.
Best part, one small bottle lasts for a year.
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
2009 KENWORTH T800 (INOPERABLE) (A63569)
2009 KENWORTH T800...
2019 ALLMAND LIGHT PLANT (A63569)
2019 ALLMAND LIGHT...
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
2007 Grove RT530E-2 4x4 30 Ton Rough Terrain Crane (A61572)
2007 Grove...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
