Log splitter and a flying log - safety
/ Log splitter and a flying log - safety #142
I am using a goal tenders helmet with the steel face guard after the last incident.
/ Log splitter and a flying log - safety #144
That or a full face football helmet seems like a great choice. I've had a couple of friends who had their face crushed in pretty random accidents, and the surgeries and rehabilitation were pretty extensive, with some parts like sinuses not readily candidates for full reconstruction.
All the best, Peter
/ Log splitter and a flying log - safety #145
All the best, Peter
Yeah after seeing the force that split came off at, I realized then that I never want to chance that again!
/ Log splitter and a flying log - safety #146
Over the years I burned wood - I split 95+ chords. I never had a split kickback or blowback on the splitter. However there were those times - driving the wedge thru a big tough pine knot. Put the hammer down and step back behind the tractor. Let the splitter fend for itself.
I had two pine trees kickback - two times - when felling. Tree split in half - from the chainsaw cut - up about 30 feet toward the top. The top half of the split tree came roaring forward - like a bolt being shot from a crossbow. A good helmet would have been where my remains would have collected. If I had been standing directly in front of those trees.
Further checking showed both trees had a large crack - running up the tree. Caused by something - UKN to me. Maybe - lightning.
/ Log splitter and a flying log - safety #147
So this very thing happened to me this weekend. Was splitting some white oak and it popped and the split went flying away from me with such force that had it hit me in the face, very bad things would've happened. I have split probably 200 cord with this splitter over the last 3 years and it's the first time it's ever happened. I was googling what sort of helmet could be used in this situation because I can't see a forestry helmet with the flimsy face shield protecting my face. That's how I found this post. Anyways, anyone got leads on a forestry helmet that has a more stout face shield?
I've been looking at the Milwaukee BOLT hard hat solution that came up in another thread. They offer an ANSI Z87.1+ rated face shield for it. The BOLT also gets a very high rating from Virginia Tech.
/ Log splitter and a flying log - safety #148
I've seen guys using full face shield motorcycle helmets when splitting...
I've never seen my splitter do that and I'm convinced it's because of the design in the wedge.
SR
/ Log splitter and a flying log - safety #150
SR
Could be. My wedge is a very wide angle, with a dull edge.
Occasionally on certain hard, dry pieces, it’ll pause for a moment at the start of contact, and then, Pow, the wood splits apart violently. There’s no air in the hydraulics, but there’s enough flex in the hoses, when the pump stages, to allow a very brief pause in the wedge, while apparently the pressure builds.
I imagine, a slim and/or sharp wedge design would be less likely to do this
/ Log splitter and a flying log - safety #151
I still split by hand. Log splitters aren't cheap.
/ Log splitter and a flying log - safety #152
I split by hand until I was about 60. If you heat with wood, a log splitter gets to be affordable. It gets even more affordable as you get older.
/ Log splitter and a flying log - safety #153
I bought a Champion splitter right at the end of last season, when they had them on clearance. At the time, I fed an indoor and outdoor fireplace at out old place, and I have access to all the standing dead oak I can use. Our expectation with our retirement home is that it would also have wood fireplaces or wood stoves. NOPE! Our retirement place has (2) ventless gas fireplaces (one inside and one outside) plus a fire pit.
I have to admit; I love the indoor gas fireplace. It throws out a ton of heat at the touch of a button, and I won't part with it. I'm not giving up hope though. We're building a game/trophy room and it will have a wood burning stove, plus the outdoor fire pit. I'll make use of it yet. Last time I was at the deer lease, I saw a huge pecan had uprooted in the bottom land. I'll chunk it up and bring it home to split and burn. Great wood to burn and cook over.
/ Log splitter and a flying log - safety #154
Pecan BBQ, yum!!!
All the best, Peter
/ Log splitter and a flying log - safety #156
I heat with oil and wood, but soon it'll be heat pump.
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
20' One-Trip Shipping Container (A66285)
20' One-Trip...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
Cattle Feeder (A65640)
Quick Attach Backing Plate (A65579)
Quick Attach...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
