OP
pipefitter
The tractors are identical, except for the 208 hours on the used unit. Both have a QA bucket, and R-4 tires, neither has a grapple, or a tooth bar.Why I gave you the "bare tractor" numbers is because that gets to the root of "apples to apples".
Tractors vary enormously in configurations and set ups. The "bare tractors" are all the same - just the power source, no extras.
So when you look at your 22,366 and 19,504 numbers - you have to drill in to that and find what specifically they are equipped with and what those values are. For example - the loader and bucket (2 different "attachments"). Does one have a grapple in that price? A set of forks? Is one bucket a heavy duty bucket and another a light material bucket? Does one bucket have a tooth bar on it and another a smooth edge? Does one tractor have R1 tires and the other R4? What about R14 or turf tires?
If they can give you the break down of how those numbers fall down to - bare tractor and every accessory/attachment (again - loader and bucket are 2, not 1) then I think you will have a better understanding of those values and if one is worth it over the other.
