Homemade Tractor Sunshade
/ Homemade Tractor Sunshade #1
bsekf
Gold Member
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
I would like a sun shade for my utility tractor. But have a problem with the price of custom built. Anybody got any suggestions? Fabric will not work.
/ Homemade Tractor Sunshade #2
I made this with a 4x5 sheet of aluminum over 2x2 steel supports welded to the roll bar. Been a few yrs. Works great. FYI could not afford any more height and still enter the barn 8ft door.
/ Homemade Tractor Sunshade #3
We talking Sunshade or Roll-Over Protection or Combo? Very much NOT the same thing.
If it has ROP, then I would think about doing -- adding some cheap-fast-quick with either 2x4s and plywood (yeah, I know -- Red-Green and all) and/or Unistrut (my favorite thing), with muffler-pipe clamps, and maybe some plywood. See what you like, and then you can (very easy and cheap) change things around until you are happy with it.
/ Homemade Tractor Sunshade #4
Golf cart "roof" from a cart salvage yard.
/ Homemade Tractor Sunshade #5
I welded 1" barstock with a 1/2" hole into the ROP using the canopy frame as a guide.
The barstock in the canopy is threaded so there is no need for a nut.
I drilled a 1/4" hole through a 1/2" bolt to drill the holes so the alignment is perfect.
Also added a couple tabs to hold things in place while I add the bolts.
Makes it easy to install and remove.
The other gussets bolt to factory fasteners. I added an LED light tied into the rear lights with a plug I added. The top is plastic riveted to the frame.
/ Homemade Tractor Sunshade #9
I too used a gold cart top from a used golf cart yard. $30 Braced it with 1" steel tubing on hand, and spent $10 for paint. Painted the top part white to reflect sun, and the bottom red to match the tractor. $40 all in.
/ Homemade Tractor Sunshade #10
I used a golf cart roof for mine. Custom fit and easy to work with.
/ Homemade Tractor Sunshade #12
I once used a plastic/fiberglass basketball backboard as a canopy
/ Homemade Tractor Sunshade #13
Hard to tell from picture, hopefully you are out of drip line. Very cool looking. I'm glad we don't get brutal sun/heat up here or I'd be trying to fabricate one as well.
