deere 755 3 pt not working
/ deere 755 3 pt not working #1
somanytractors
atlanta, ga
several
I have a 755 I got not running and don't know it's history.
It has the levers and quick couplers for a loader but no loader.
It runs and drives great and the power steering works great.
If you move the lever for the loader it will bog down like it should.
The 3 pt does nothing at all. No bog no lift, nothing.
I was told that on the 755 if you remove the loader you need a jumper to get fluid to the 3 pt.
This makes no sense to me as the loader only has 4 hoses 2 for lift and 2 for tilt I would think.
Anyway, if I do need to jump it I dont know where to put the jumper.
The couplers for the loader are numbered 1, 2, 3, and 4.
Do I need a jumper or is it something else?
I've attached a few pics. I'm not at all familiar with these little deeres so I really need it spelled out.
Any help is greatly appreciated.
John
/ deere 755 3 pt not working #2
John
Your tractor is really a Yanmar. Either ask in the Deere section or the vintage Yanmar section.
The TM1360 Technical Service manual can be found for free on the YTOG site. This will show you the typical hydraulic plumbing with the Yanmar loader on the JD755.
/ deere 755 3 pt not working #3
If the directional control valve stays with the tractor when the loader is removed it should not require a jumper for the 3 point to work.
How many lines connect to the control valve including the four for the loader? 6 or 7?
Not sure why I posted it here. Wasn't thinking. deere or yanmar probably would have been better.
Thanks for the info. I didn't find the manual on that site but before I didn't even know what to search for. I googled "TM1360 Technical Service manual" and I did find a free download.
Thanks!
I'm pretty sure that everything stays with the tractor. It only has the 4 quick couplers. And the lever to work the loader is on the tractor. What I was seeing about a jumper didn't make any sense to me. I'm thinking there is no need for a jumper. I don't see any other lines from the block that controls the loader. I think the block in front of it has the in line and the relief valve. Other then that I'm not sure. I put it all back together, and then decided that I really need to see if I can get the 3pt going. I'm going to pull the covers off tomorrow when its warmer. Then I'll be able to see what lines go where, but I don't really remember any lines for the 3pt. Is there anything that would let the loader lever bog the motor but not send anything to the 3pt other then the directional valve? I dont see any lever on any of the valves either, other then the loader control. Is the directional valve automatic or should there be a lever somewhere?
Thanks for your help!
/ deere 755 3 pt not working #6
Your 755 does have a Yanmar engine, but it would have been assembled in Horicon, WI. This is a pic of the manual you want (print version might be pricey). The 3 point was standard on the 855 and 955, but it was an option on the 755. It's controlled by the sliding lever to the right of the seat. Assuming all the bits are there (and the same as my 855), look for this round valve under the seat which might be turned so far (too far?) as to shut off the 3 point operation.
/ deere 755 3 pt not working #7
Thanks!
To find the manuals on the YTOG, you must login to see the WIKI page to have access.
Just visiting the site only give very limited offerings.
There are other manuals too related to your machine over there. :)
/ deere 755 3 pt not working #8
View attachment 4889089View attachment 4889090
Yes, the 55 series had to be assembled in the USA as a kit tractor supplied by Yanmar due to the import and tariff restrictions back in the day. This kept the import costs to be lower and the Deere union workers happy.
/ deere 755 3 pt not working #9
This manual being the OPS manual, is free to download off the Deere site. (y)
I've moved this to the jd section. https://www.tractorbynet.com/forums/threads/deere-755-diagnosing-3-pt-problem.643145/
Again thanks for directing me to the manual. Everything makes a lot more sense now! It doesn't look all that different from what I'm used to. Just configured a little differently, smaller and buried under everything.
I went o
I went out and pulled off the covers again. The main pressure line comes it to the right side of the 1st block. On the left side of the 1st block is one line that goes up to the front of the tractor, power steering as best I can tell.
The second block has the lever for the loader with 4 lines coming off the top and going to the quick couplers. That block has 2 housings sticking out the left side but no lines.
There is one other line I can see coming from the front and hooking into the left side of the housing near the rear. I believe it's probably the return from the steering. Beyond that theres the lever for the 3pt and the link to tell it where the arms are.
Thats all I can find going into the system.
/ deere 755 3 pt not working #12
I went o
First for clarity are the 3 point arms lowered and won’t raise or are they fully raised and won’t lower?
From your description above it almost sounds like that tractor has a priority flow control that supplies oil to the power steering and excess flow is directed to the loader and 3 point. You stated engine works when activating loader function so that indicates flow going to loader valve.
The power steering flow may come back and act as charge flow for the hydrostatic transmission. ( presuming HST) you state steering is working fine.
With out a hydraulic schematic I am unsure of how oil is supplied to the 3 point. Typically it would be via power beyond from loader valve.
/ deere 755 3 pt not working #13
I might have some JD755 tech info. I'll look for it tonight after work.
/ deere 755 3 pt not working #14
It turns out I do have a older 1985 complete tech manual covering the 655, 755, 855 & also the X56 series JDs. That's not so surprising, I always hoped to own one of those models someday... They were popular mowing machines.
But I also found online a later & better version of the tech manual that you can download it for free.....
It's a large .pdf (41 MB) and is also known as JD Tech Manual TM-1360. Here is the link:
I took a look through that manual and it is beyond excellent. The section you want is the very last section in the book. After you download it, go to Section 270-05-1 and read a few pages. It explains your hydraulic system well. Then go farther to Section 270-15-1, and there is the start of the schematic diagram that Oldnslo was looking for. He mentioned steering priority; the answer is on that page.
Not only are the drawings and photos good, but it has a step-by-step troubleshooting guide that will enable you to troubleshoot your tractor hydraulics yourself with a few hand tools and a simple hydraulic pressure gauge test kit (about $100 on Amazon). I wish more manuals were this well written.
Several of us here on TBN can help with your hydraulic questions as they come up.
These Yanmar/JDs - the 655, 755, 855 - are only slightly different than the normal tractor hydraulic system we see on most compact tractors. With a good manual to follow, tractor hydraulics are pretty straightforward. And this this has to be one of the best workshop manuals I've ever seen.
We often start hydraulic trouble shooting by cleaning out the cleanable sump filter on tractors that have them. The JD755 has one of those, so removing it and cleaning it is a good place to start. Getting that filter out involves first draining the trans/hydraulic fluid so be prepared for a lot of oil.
Good Luck,
rScotty
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Bucket (A64194)
Pemberton Inc...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
Buckhorn Poly Feed Box (A66408)
Buckhorn Poly Feed...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
