Kubota sub compact loader bucket cross references?
/ Kubota sub compact loader bucket cross references? #1
Dover7838
Kubota bx2200
Have a BX2200 with LA211 loader. 48” bucket. Bucket is bent. Appears OEM direct replacement part 75538-50000 is long gone.
Found a BX23s bucket locally at a good price. Despite my google searches, I cannot find a good cross reference if this bucket will fit my LA211? Overall mounting dimensions are almost exactly the same. Are pin positions the same?
Obviously rebuilding current bucket is an option, but would like to fabricate the bent one into a snow pusher box since I’ll be cutting it up anyway.
Thanks!
/ Kubota sub compact loader bucket cross references? #2
Thanks!
I think you are in a good position to end up with 2 useful buckets: the old one modified to be a snow pusher and the BX23 bucket to replace it for normal duties. The reason I think this is (for my BX2200) I bought an old who-knows-what brand FEL bucket much larger than the std LA211 bucket. Probably a foot wider, higher and roughly twice the cu ft load capacity. The old, large, extra bucket was modified by a local welding shop to mate up with the FEL pins and brackets on the LA211 frame. Not a big deal and works fine. Of course the little BX2200 is easily overloaded with this rag-tag extra bucket but I know my limits and what not to try with it. I did it as a quick and dirty way to drastically increase the fluffy snow capacity of my loader. A low density load (like snow) doesn't overload anything.
So your scenario is somewhat different but I think you should be able to adapt the BX23 bucket to the LA211 loader frame easier, actually, than the contraption I had adapted to mine. Don't worry too much about exact measurements, just modify what you have to. Good luck.
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
378891 (A61166)
378891 (A61166)
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A61568)
1987 International...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
