M7040 sudden fuel line separation
/ M7040 sudden fuel line separation #1
Dave M7040
Elite Member
Williamstown Ontario Canada
Kubota M7040 Nuffield 465
In my area a major storm is coming and because my wife is very ill, I was readying the M7040 and blower so I could keep our lane open for medical supplies or an ambulance.
I backed the tractor out of its storage location and was getting ready to drive it into my heated work shop. When I got out of the cab to open the shop door I noticed large quantities of a clear liquid dripping unto the ground from between the rear of the engine and the fire wall. The loader made it impossible to see but I feared something major happened to the steering valve.
When I got the loader off and was able to see, I noticed a fuel line leaving the injection pump had separated from a plastic check valve and fuel was pouring out.
The check valve had no raised portion on its nipples to help the wire clamp hold it in place.
The check valve and inside of the rubber fuel line were cleaned with brake clean and a much more robust spring type hose clamp was installed.
Owners of similar machines may wish to review the condition of the clamps and check valve and avoid a bad scare.
The check valve is used because the return line just dumps into the top of the fuel tank and without the check valve the injection pump could inhale air from the tank when the engine is stopped.
Other tractors I have known have the return line extend to the bottom of the tank so the open end of the return line is always submerged.
Dave M7040
/ M7040 sudden fuel line separation #2
Thanks for the picture and I identifying what you were describing in it, very helpful to understand your issue.
I hope your wife recovers from her illness and is not in need of an ambulance.
/ M7040 sudden fuel line separation #3
If you need a stronger hose clamp they make what are called "fuel line hose clamps"
/ M7040 sudden fuel line separation #4
any chance the "Barb" broke off the check valve and thats why you didn't see it. It may be still in the hose.
/ M7040 sudden fuel line separation #5
Was the separation right before the check valve or right after? I'm just wondering why there would be that much pressure on a return line. Is the line kinked or pinched going back to the tank? Is the tank properly vented? Did the check valve get froze or plugged?
No barb does not exist on these valves. Plastic end was smooth and unbroken.
Judging by the simple wire clamps Kubota uses all along this return line they are not expecting any pressure.
I never have water issues with my fuel but that does not mean condensation coming back from the tank affected the check valve.
I made the post so if another owner is suddenly faced with leaking fluid they dont panic like I did when in the end it was just a simple problem.
I understand from my dealer they have seen this on other M series machines.
The line came off on the IN side of the check valve
Dave M7040
/ M7040 sudden fuel line separation #7
Dave - I hope your wife is better soon.
AND - BTW - I had the EXACT same thing happen on my M6040. Kubota uses those worthless spring tension clamps. Service tech came out and replaced the spring tension ones with ones like thclimer pictured. Problem solved.
Thank you, unfortunately my wife's condition will only get worse.
Dave M7040
/ M7040 sudden fuel line separation #9
Those little "check valves" have short, smooth, tapered fittings. I fought this and thought I won but then eventually you find all your $$$ diesel is going on the ground.
To fix it, I used new Kubota fuel line, and spring clamps like Briggs and Stratton uses. It was too small for true hose clamps. Never a problem since then.
Fuel line is fuel line, but I tried new fuel line, and it just wasn't gripping the valve very well. The Kubota fuel line fits great.
/ M7040 sudden fuel line separation #10
Bringing up an old topic because this weak link in the fuel system just got me too! Fuel all over everything a couple nights ago. Glad I didn't burn my M7040 to the ground.
I pushed the hose back on the check valve and tried to make the spring clamp tighter, but I have zero confidence that was a permanent fix. Will check at the local mower place tomorrow to see if they have clamps like the one in post #3 above.
/ M7040 sudden fuel line separation #13
Was the spring clamp shown in the picture still on the hose? If not, I wonder if it rusted a broke, and that in turn allowed the hose to vibrate its way off?
/ M7040 sudden fuel line separation #14
There isn't a spec of rust anywhere on this machine, including on the spring clamp. It looks just like the photo in post #1, clamps and all. A mechanic friend of mine (motorcycles, not heavy equipment) suggested that I use cable ties, tightened with a cable tie tensioning tool. That seems easier than finding the right size clamp at the mower place and certainly will tighten the connection better than the factory spring clamp. I'm going to try it tonight.
/ M7040 sudden fuel line separation #15
The Zip-Tie will probably work For a more robust solution I don't think you can beat the fuel line camps. Amazon sells an assortment of them in stainless steel for a reasonable price:
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
2021 Mac Trailers T/A Walking Floor Trailer (A64556)
2021 Mac Trailers...
2010 48 ROLL OFF TRAILER (A65643)
2010 48 ROLL OFF...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
