T264 Cruise control
/ T264 Cruise control #1
tylera189
TYM T264
Picked up a leftover 264 several months ago, realized once I got home that the cruise isint working. Finally got around to messing with it. Yes its under warranty, and no I currently dont have time to take it back to dealer. So anyways just want to verify that the switch is a momentary switch in both directions? Seems odd that way, but appears it has a cruise on relay and a cruise off relay. When I select ON cruise engages but once I release button it kicks the magnet back off. I have cleaned pedal, and magnet, and shimmed magnet closer to pedal, I have also verified brake light switch adjustment, and it was not right and lights were on all the time, but is corrected now. Thanks for any insight.
64 views and no one can tell me if the CC switch is momentary both ways? I must be the only one with a TYM that has CC. LOL 🤣🤣🍻
/ T264 Cruise control #3
On my 2400H Branson the button is maintained. Push on = maintained for cruise and button illuminates. Push again = off
If only one button I would suspect should be a maintained circuit.
thanks, ya this is a on/off/on switch. Just wondering if the switch is supposed to stay in the cruise ON position, and then the off side is momentary. Just racking my brain trying to figure out how it could be momentary and then be able to keep the relay closed.
/ T264 Cruise control #5
Did you get an owners manual with your tractor or was it used from private individual. If remember correctly my manual explained then operation of cruise.
/ T264 Cruise control #6
I haven't even tried the cruise on my tractor. I don't have long stretches of areas to mow.
/ T264 Cruise control #7
I've attached the schematic from the manual for my T233. It shows the two relays and the wiring from the switch to the relays. There is no information on teh cruise control other than to check teh fuse.
  • T233HST,T273, Service Manual 210.pdf
/ T264 Cruise control #8
Wow, What a clean copy of the electrics!! Thanks for this Jigs, I've been frantically searching for a "readable" copy of the electrics for several days -- now two different sources show up!! Great for me! I printed this out and am going to get it enlarged so I can somehow figure out where my short is in my system. I also found a mobile tractor electrician that I believe I'm going to farm this job out to. I just wanted to have a schematic available for him and I.
/ T264 Cruise control #9
The service manual has the schematics. You should be able to get teh service manual through TYM but you may have to to to the TYMWorld site, and fill out a form. They don't typically have teh service manuals available for download on the site. But do have a form you can fill out and ask for things they don't list. Typically the service/repair manual is one of the ones you have to ask for.
I have manual, it doesn't give the details I need.
/ T264 Cruise control #11
Operators manuals are just that. How to operate the tractor and what controls do what. But the operators manual is silent on the how things work, and limited in troubleshooting. To get those details you need the service manuals.
/ T264 Cruise control #12
It is a PDF, so if you have a printer which does Tabloid (11X17), or any of the larger sizes you can just increase the print size to match the larger paper. And if you happen to have a full version of Adobe Acrobat, you can even annotate things, and save the annotations.
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2004 Dodge Ram...
2019 KOMATSU WA320-8 WHEEL LOADER (A64279)
2019 KOMATSU...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
PALLET OF AMMO BOXES (A64281)
PALLET OF AMMO...
