How about a grease cartridge thread?
/ How about a grease cartridge thread? #61
One thing I might add and that is the CV joints especially on my powered implements require a certain number of strokes on a level gun to fill properly and why I use manual lever guns. You overgrease a CV joint, you blow the seals out of them and CV joint's are expensive to replace. Only time I grese until visible in any situation is when I'm told to.
/ How about a grease cartridge thread? #62
Technically I get my grease for free from the truck stops . . . I'm a long distance truck driver and I get anywhere from 1-7 points on there "rewards card" for each gallon of fuel/DEF that I pump ... 1 point = 1 cent ... So I use them to "buy" my supplies!
I do prefer the cardboard tubes and "tin" pop tops ... And I usually only have a choice of Lucas Red & Tacky, so that's what I get, rarely is there green given the shelf space, occasionally some truck stops carry the Mystic Red ... I like the LRT.
I stick my knife in the top to get the plastic pull tab started, so I can slowly and in a controlled manner remove it ... The new stuff is "runnier" a quick release of the plastic pull tab can send a bit flying out of the tube!
/ How about a grease cartridge thread? #63
I found TRC 880 crown and chassis grease and started using it. No bleeding or oozing oil from the grease from what I have seen. It is very good at staying where you put it. Only time it oozes for me is when I'm pumping it into u-joints and such and some old grease gets pushed out. And that stuff just clings on to what ever.
In the past I used pounds of power punch grease and chevron ultra-duty. Both excellent greases but would bleed oil from the grease and really attract all sorts of gritty stuff to the area of pins, pivots or what ever. The trc stuff just does not do that. My grease gun is oil free after switching over from the other greases in not quite a year. Something the other greases would have done by now.
Old school aluminum pull tabs and paper tubes to boot with the trc grease....
/ How about a grease cartridge thread? #64
I've been a Lucas Red and Tacky user for about ever. But I hate what they've done with the plastic tubes. Frankly, the grease doesn't seem the same either. What are we using for lithium spindle / chassis grease that still comes in cardboard and works well?
Sorry to just be getting back with you on this. I can't get the email part to work so I will do a reply here. Check out Lube Shuttle grease guns. The cartridge screws into the grease gun. There is no mess or anything. A little pricey to get started but well worth it. Grease doesn't turn to oil and run out in the floor or down the wall. Wish I had one years ago. They have different grades of grease cartridges for whatever. Just go to Lube Shuttles website. Hope this helps.
/ How about a grease cartridge thread? #66
did you get a M18 or a M12 gun? I have a M18 impact. I checked on the Milwaukee guns new and used W/no batt since I have one. I ended up buying a Chinese kit W/battery for $110 off amazon. works great,comes with a 2.5 ft long hose and case. works really good and strong & easy to switch cartridges and bleed the air
/ How about a grease cartridge thread? #67
I got the M18, just the tool only...no batteries or charger. There was a black Friday flash sale at Home Depot for $170.
I have the M12 impact too, I love that little thing.
/ How about a grease cartridge thread? #69
My grease guns, handle powered $25± work great. Light weight, fit nicely in tool box, no dead batteries. I keep it in a plastic grocery bag to keep the sticky inside.
Yeah, these battery grease guns are better than already been sliced bread. I started to buy Mystic grease and sent the RNT packing. Works great and I don't have to screw around with their crappy tubes.
/ How about a grease cartridge thread? #71
I bought the HF Hercules gun last year and it works great. Every couple of months they run a special sale: buy a 20V battery with charger for $99, and get a free tool. I chose the grease gun that regularly sells for $139 without a battery or charger.
/ How about a grease cartridge thread? #72
My Christmas gift this year. Sure makes the job a lot easier.
I like those but they are like a battery operated watch. Dead when you really need it.
/ How about a grease cartridge thread? #73
I have a lincoln Powered grease gun, It was a gift to. I no longer run equipment with grease points numbering into the 30's so it mostly just stays on the shelf.
/ How about a grease cartridge thread? #75
I've found that the trick with battery-operated tools is to NEVER store the tool with battery attached. Store the battery separately from the tool and it will be good to go even a year later.
/ How about a grease cartridge thread? #76
Also, never store a lithium-ion battery fully charged.
Tesla, Ryobi (and maybe others) warn that for long-term storage, a charge of less than 75% is recommended for longer battery life. They define long term as more than 30 days. When I first started using Ryobi 40 volt tools, I always brought them up to 100% charge and when the first battery failed just after the 3 year warranty ended, I discovered by reading the instruction manual about the storage charge vs usage charge.
I now use a home-made device that stops the Ryobi charger, when the battery is at 75%. If I know I will need heavy use of a tool, I will bring it up to full charge first. My batteries are now lasting 6 years and still going strong.
/ How about a grease cartridge thread? #77
I messed up!!
I bought a 5 gallon pail of moly grease quite some time ago and I finally bought a grease gun filler cover that goes on top of bucket that can pump grease into my grease gun rather than replace the cartridge.
Well I didn’t notice the inside grease cover seal that slides down into the bucket to prevent air from being sucked into pump. Now I have a 3/4 full bucket that cannot be pumped due to air.
Any ideas on how to remove trapped air from bucket??
Too messy to hand pack & too expensive to throw away.
/ How about a grease cartridge thread? #78
Which type of bucket cover/grease gun filler is it.
One with the hand pump that the stem goes through the cover and the follower plate, that pumps into the larger fitting on the grease gun head.
Or is it the type where the head of the grease gun is removed and then the gun body sits into a "cup" in the follower plate and you pull the rod back in the grease gun to fill it?
You should be able to remove the top cover and press the follower plate down to expell the air pocket, you may have to work it from side to side.
It is still very messy but many have been know to remove the follower plate, remove the grease gun head, insert the body into the grease then retract the plunger of the grease gun into the gun sucking the grease into the barrel.
It is a dirty nasty job to fill the grease gun that way.
Years ago that was the way we filled grease guns, then when it wouldn't suck the grease into the gun we would hand pack the grease gun to get the very last bit out of the pail.
/ How about a grease cartridge thread? #79
This is more then ridiculous, it is assine.
/ How about a grease cartridge thread? #80
Back in the day it was always stick the barrel into the grease and retract the Plunger. Put the lid back on tight or the cows would lick the grease. I always put a large plastic bag over my grease gun leaving only the tip out.
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
JCT 72" QA Rotary Tiller (A64912)
JCT 72" QA Rotary...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
2018 Toro Workman HDX-D Diesel Utility Cart (A66734)
2018 Toro Workman...
2016 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2016 Chevrolet...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
