Tractors and wood! Show your pics
/ Tractors and wood! Show your pics #25,891
Speaking of vertical splitters - is it generally a thing that they move around when splitting vertically?
No. As long as the round stays on the foot, movement is not really an issue.
Now, on those rare occasions when a round slips off the foot, you'll find the splitter slowly pushing itself skyward, as the wedge comes down. Never a big deal, just reverse, reposition, and carry on.
/ Tractors and wood! Show your pics #25,892
Speaking of vertical splitters - is it generally a thing that they move around when splitting vertically? As the big round gets split parts of it get shoved into the ground and the whole thing moves around which can be a pain; I suppose having a bigger "foot" would help but I wonder if that would also interfere with the normal horizontal split, or at least interfere with me throwing splits into the tote.
Mine is attached to 3 point, so no movement while splitting
/ Tractors and wood! Show your pics #25,893
I like that style, stick one of those big rounds under it, then slide the others out of the bucket onto it and split away no lifting involved.
/ Tractors and wood! Show your pics #25,894
Like other posters said, should have no movement at all as the rounds just rest against a foot.
Here is a 12T vertical splitter splitting eucalyptus, powered by a Kubota L175 just idling along. No gas engine screaming.
/ Tractors and wood! Show your pics #25,895
I have had mine squirm around some. I can’t remember exactly why, maybe an odd shaped round that part of it’s pushing against the ground instead of the base.
/ Tractors and wood! Show your pics #25,896
That's a nice splitter in the video. It has a nice big base to move the block around on instead of a small foot like on my Husky horizontal/vertical splitter. On big blocks I use vertical. I work off of my carry all to give me a smooth surface to work on. It also makes it easy to keep the block on the foot and against the beam - stays there on it's own, no lifting and leveraging the block required.
gg
/ Tractors and wood! Show your pics #25,897
gg
Same exact splitter I run, but mine's been mod'd with bigger pump, hoses, and a bigger engine to turn the large pump. Works just the same, but with 6 second full travel + return time, versus the original 11-12 seconds.
/ Tractors and wood! Show your pics #25,898
My rounds initially are on the foot but I find that very stingy wood (most of my oak) doesn't always come apart with the first split so part(s) of the round invariably end up hanging off the foot and may be pushed into the ground.
/ Tractors and wood! Show your pics #25,899
Nice trailer, looks to be a good size and rather handy
Thanks, it has come in handy and was free! It was abandoned on the side of the road for weeks with a wheel missing and torn up lug nuts and the registration plate removed. The town wanted it gone, so I grabbed it, threw some of my old Jeep wheels on it and the plywood sides. I welded some angle iron onto the axle to beef it up.
(2) 140 Gallon Saddle Tanks w/Brackets (A60463)
(2) 140 Gallon...
1990 TRAILMASTER CRUDE TRAILER (A60736)
1990 TRAILMASTER...
KMC 3pt 11 Shank Ripper (A60462)
KMC 3pt 11 Shank...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
