John Deere 670 Compact Tractor Alternator/Charging Issue
/ John Deere 670 Compact Tractor Alternator/Charging Issue #1
fratra
Somewhere, GA
John Deere 670
I have a JD 670 compact from 1996 I think. The battery light is on and not charging (confirmed with multi-meter), only getting 12 volts on battery while running. I've replaced the alternator twice thinking the first may have shipped bad. The second alternator the battery light went off initially and stayed off for several starts. As soon as I started backing it out the light came on and stayed on again. I did try changing the rectifier/voltage regulator and that didn't help either. Using a multi-meter I don't see any voltage coming out of the alternator connector wire either. I don't see any inline fuses I can find anyway. Any ideas??
/ John Deere 670 Compact Tractor Alternator/Charging Issue #2
You need the TM1470 service manual to debug this issue in the troubleshooting section.
(it's for free on the YTOG)
TM1470 Technical Shop Manual 670 770 790 870 970 1070.pdf
Awesome! Thanks for the help.
/ John Deere 670 Compact Tractor Alternator/Charging Issue #4
I am having the same issue with my 670. I have replaced the battery alternator, voltage regulator. Battery wont charge and I also get not voltage to read on the alternator output. Did you ever figure out anything? Thanks.
/ John Deere 670 Compact Tractor Alternator/Charging Issue #5
/ John Deere 670 Compact Tractor Alternator/Charging Issue #6
Same advice since this PDF goes thru the troubleshoot section to debug the problem.
2017 BX2680 Sub Compact Utility Tractor (A61307)
2017 BX2680 Sub...
2020 Chevrolet Tahoe (A60352)
2020 Chevrolet...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A60352)
John Deere 12in...
(3) Mini Excavator Hydraulic Thumbs (A60463)
(3) Mini Excavator...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2005 Jeep Grand Cherokee SUV (A61569)
2005 Jeep Grand...
