John Deere 670 Compact Tractor Alternator/Charging Issue
   / John Deere 670 Compact Tractor Alternator/Charging Issue #1
fratra
Somewhere, GA
John Deere 670
I have a JD 670 compact from 1996 I think. The battery light is on and not charging (confirmed with multi-meter), only getting 12 volts on battery while running. I've replaced the alternator twice thinking the first may have shipped bad. The second alternator the battery light went off initially and stayed off for several starts. As soon as I started backing it out the light came on and stayed on again. I did try changing the rectifier/voltage regulator and that didn't help either. Using a multi-meter I don't see any voltage coming out of the alternator connector wire either. I don't see any inline fuses I can find anyway. Any ideas??
   / John Deere 670 Compact Tractor Alternator/Charging Issue #2
You need the TM1470 service manual to debug this issue in the troubleshooting section.
(it's for free on the YTOG)
TM1470 Technical Shop Manual 670 770 790 870 970 1070.pdf
Awesome! Thanks for the help.
CAT 289D3 (A58214)
CAT 289D3 (A58214)
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2004 Ford E-350 Bus -6.0 Powerstroke Diesel - 55k Miles - Inoperable/Non-Running (A56438)
2004 Ford E-350...
Chemical Containers Tank (A57148)
Chemical...
Towable Chemical Applicator Sprayer (A59228)
Towable Chemical...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
