grsthegreat
Super Star Member
I’ve never seen a modern diesel tractor without glow plugs?
I have a 2001 New Holland and a 2007 JD both over 60 hp. No glow plugs on either, block heater on the JD and fuel heater on the NH.I’ve never seen a modern diesel tractor without glow plugs?
There are many diesel engines built today that have no glow-plugs, JD 2.9L/179 cid, 4.5L/276 cid & 6.8L/414 cid are prime examples. These engine are used in many JD tractors currently being manufactured today.I’ve never seen a modern diesel tractor without glow plugs?
Only indirect injection diesels will have glow plugs.I’ve never seen a modern diesel tractor without glow plugs?
I don’t think that’s true but might be?Only indirect injection diesels will have glow plugs.
I thought you posted a video earlier with the engine actually turning over normally. What did I miss? (And, was the point of the 2nd video, 'how to burn up stuff with battery cables'?) ;-)Was able to get the starter off and bench (ground) test it:
Bench test
Any thoughts on the state of the starter?
It wasn’t working, then it was, then it wasn’t. Intermittent until it finally quit for good.I thought you posted a video earlier with the engine actually turning over normally. What did I miss? (And, was the point of the 2nd video, 'how to burn up stuff with battery cables'?) ;-)
Also note that it's possible to activate the solenoid, which will move the Bendix forward, without powering the motor winding. Which is what it *looks* like you did. You don't appear to have power applied to the high current supply terminal, when you power the small coil terminal (which activates the solenoid and moves the Bendix). You then appear to touch the high current supply terminal, but don't activate the small coil terminal. And touching the frame of the starter with the hot jumper lead is dangerous; it could weld itself to the frame, and wreak all manner of havoc. At minimum, you could get one of those sparks in an eye.
Good post, thank you. I’m keeping the starter with the hopes of rebuilding it one day. (Like a million other things I hope to do one day.)That's a nice-looking heavy-duty starter like the one for my IH3444. It stopped working, so I disassembled it. Cleaned it all up, refinished the brush contact surfaces (commutator) with sandpaper by chucking the armature shaft into a 1/2" drill chuck. Drill was clamped into a bench vice. Refinished the commutator surface bar by smoothing out the slightly rutted, worn copper surface with sandpaper placed over a flat file and spinning the drill motor slowly. Cleaned all bearing surfaces and regreased with Pennzoil Marine water repellant grease. Flipped over the solenoid contact points 180 degrees so new surfaces would make contact with fresh refinished surfaces. Installed new brushed that I matched up at the NAPA dealer in town. Had to do some slight modifications with a file to get them to fit back into their slots. Reassembled, and reinstalled in tractor. Works like new. Should be good for another 40 years.
I am not sure what indirect injectors are. My 2003 diesel car's engine has injectors that bolt into the head, not into the intake manifold. Same engine has 4 glow plugs bolted into the head. Injectors and glow plugs on the near side. Intake and exhaust manifolds on the far firewall side. Pretty sure injectors that squirt into the combustion chamber are not indirect. That said my 1984 gas VW with 4 fuel injectors sprayed into the intake manifold. Are those indirect injectors?Only indirect injection diesels will have glow plugs.
I dunno for sure but I think indirect injectors in diesel engines inject the fuel into a small chamber that is separate from the main combustion chamber. I believe this is how my Yanmar YM2310 works. So the fuel is not injected into the intake manifold. It is instead subjected to the very high compression that happens in a diesel engine but is not injected into the main combustion chamber but is instead injected into the small chamber that is in communication with the main combustion chamber. See the link: Indirect Injection Vs. Direct Injection Engines | Big Bear Engine CompanyI am not sure what indirect injectors are. My 2003 diesel car's engine has injectors that bolt into the head, not into the intake manifold. Same engine has 4 glow plugs bolted into the head. Injectors and glow plugs on the near side. Intake and exhaust manifolds on the far firewall side. Pretty sure injectors that squirt into the combustion chamber are not indirect. That said my 1984 gas VW with 4 fuel injectors sprayed into the intake manifold. Are those indirect injectors?
Some diesels can start just fine without heat. My 1987 JD 870 (Yanmar) doesn't seem to need the intake grid heater until it gets close to freezing.
I’m in the process of resurrecting my 1973 BMW motorcycle… the starter isn’t quite as big as either one you posted… however, the replacement starter for my bike is tiny compared to the original… more torque, less battery draw and lighter weight… isn’t technology wonderful…Here’s a pic of the new starter…It’s much smaller, lighter and I believe has a gear reduction…
That is a good article. Now I know at least one of my 3 diesels is indirect injection. Not sure about my JD 870.I dunno for sure but I think indirect injectors in diesel engines inject the fuel into a small chamber that is separate from the main combustion chamber. I believe this is how my Yanmar YM2310 works. So the fuel is not injected into the intake manifold. It is instead subjected to the very high compression that happens in a diesel engine but is not injected into the main combustion chamber but is instead injected into the small chamber that is in communication with the main combustion chamber. See the link: Indirect Injection Vs. Direct Injection Engines | Big Bear Engine Company
Eric
