Arber
- Joined
- Nov 16, 2025
- Messages
- 22
- Location
- Europe
- Tractor
- Ford 3000 2.9L Diesel 1968 10 Speed Dual Range. Made in England
I recently replaced the fuel filter on my tractor and blew all the fuel lines with compressed air for extra cleaning after that went through the normal procedure bleeding the top of filter after that injection pump bleeder screw then at injectors but for some reason I couldn't get good fluid movement from the first injector in the front of the engine the other two were excellent mind you I did rebuild the pump and injectors before, the tractor did eventually start but by observing the first injector line it was moving fluid but not the same as the other two! Now the tractor is bled and starts fine but I am fairly confident that issue with line 1 is quite common because I saw another post stating just that!
What do you guys think has this Happened to you?
EDIT: I'm talking about Ford 3000 diesel
