GS650GL
- Joined
- Jan 16, 2024
- Messages
- 192
- Tractor
- LS G3038 LS XG3025, 1945 Farmall H, Farmall M, Mitsubishi MT2501D, Allis Chalmers B
Even if you have 12.6 at the key switch you can still have low voltage at the fuses because some are powered by a relay, not directly from the key switch. I was only getting 7 volts on a couple fuses when I fixed mine and it was a bad relay. Then another time I had ground issues and added the extra ground wire. The firewall ground is on the right side about half way up the firewall and the wire goes to the clutch housing. I think I attached the extra ground wire at the clutch housing also.
